panasonice tx42s31b 8 blinks
  • adamp91gvm
    • Jan 2014
    • 706
    • uk
    Re: panasonice tx42s31b 8 blinks
    Have u any idea if p42s30b is the same v sus
    • tw2005
      • Oct 2011
      • 6458
      Vsus voltage I'd expect to be the same or thereabouts.
      • adamp91gvm
        • Jan 2014
        • 706
        • uk
        I got another vsus when I was turning it on I was getting 7 blinks so I changed the transistor from my other board tested them making sure the all went from 1 to 0 and put them on now its just turning off again no blinks ?
          I think you mean Y-sustain or SN board, not Vsus which is the voltage for the Y-sustain ?
          • adamp91gvm
            • Jan 2014
            • 706
            • uk
            Yer sorry
            • adamp91gvm
              • Jan 2014
              • 706
              • uk
              #26
              Anyone any ideas
              • adamp91gvm
                • Jan 2014
                • 706
                • uk
                #27
                Think I may of sused it think one of telhe transistos has gone bad even though itd showing It going to 0
                • Biruslapio
                  Panasonic P58V11B 8 and 12 blinks error "fix"
                  by Biruslapio
                  Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                  Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                  04-13-2021, 07:13 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • Taurus12
                  Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                  by Taurus12
                  Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                  I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                  i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                  Any recommendation on what I have to do next? Thanks in advance
                  06-10-2025, 05:05 PM
                • jchon
                  Sony A1e 5-blinks help
                  by jchon
                  Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                  I found the service manual, which was critical to know where to probe.
                  https://www.manualslib.com/manual/20...1e-Series.html
                  With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                  Unfortunately the 5-blinks...
                  06-28-2023, 11:52 AM
