as above it comes on for a second then goes off i have checked voltages from p6 and im gettin 15.6v 5.5 and 3.3 it has 8 flashing lights
panasonice tx42s31b 8 blinks
as above it comes on for a second then goes off i have checked voltages from p6 and im gettin 15.6v 5.5 and 3.3 it has 8 flashing lightsTags: None -
Re: panasonice tx42s31b 8 blinks
8 blinks -- SS board or SC board. Do you get an LED glow on SC? See training manual.
(for 3D model - maybe 2D model manual available elsewhere - should still be usable.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
i can not see a led on the sc board theres is on the ss it comes on for a second then goes off on the ss that isComment
On SC or SS? Pictures of actual boards please.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I can't see any LED. There is a repair kit available which involves replacing all 7 surface mount FETs, maybe try checking them for shorts.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Perhaps try searching for TNPA##### (with ##### replaced by the numbers after TNPA printed on SC) board repair kit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have had this tv on my wall for a bitniw . Yesterday it came on for about 3 seconds and went off and will not come back on .no flashing lights .the green light comes on flashes a few times then goes off anf nothing thenComment
No green light after it goes off? Any panel glow?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
So the green light does still light, no red flashes? I'd be hedging a bet on the A board. Maybe tw2005 has a better idea.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
...1 Photo11-20-2024, 08:52 PM -
by Taurus12Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
Any recommendation on what I have to do next? Thanks in advance -
by jchonHi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
I found the service manual, which was critical to know where to probe.
https://www.manualslib.com/manual/20...1e-Series.html
With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
Unfortunately the 5-blinks... - Loading...
