Samsung LN46A530P1FXZA Black lines, wasn't the t-con
  • ultimaniac
    • Apr 2014
    • 8
    My dad recently helped some people move and got this tv for free from them because they said it was 'broken.' Black vertical lines on the left of the screen and a big wave of discoloration that pulses in and out on the right. I spent the last week or so looking for a fix and found some people say it was a faulty t-con board. I ordered a new board and installed it but the problem didn't go away.
    Does anybody know what could be wrong with it?
    Also there's this worrying green swath of pixels to the bottom left of the screen. It looks like the panel itself could be damaged but I hope it's not.
    Re: Samsung LN46A530P1FXZA Black lines, wasn't the t-con
    That looks like a bad LCD panel to me; I can't see any way that is not due to a bad panel. Sorry!
    • ultimaniac
      • Apr 2014
      • 8
      Thank you for your reply.
      Some other places I've read say that the connectors from the t-con to the panel are sometimes loose or bad. If I tap the top of the set the black wave goes away and if I put pressure on the frame at the top corner just above the lines then some of the lines fill in. Might be hoping against hope but could these be signs of salvageability?
      • Glitcher
        • Mar 2013
        • 673
        • USa
        If putting pressure on the top causes change then you could probably do the tab bond fix.
        • ultimaniac
          • Apr 2014
          • 8
          I'm unfamiliar. Can you point me somewhere where I can read up on this?
          • ultimaniac
            • Apr 2014
            • 8
            Ah, nevermind. I found some threads. Thank you, I'll reply back to this thread with results.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              It should fix the wave but it'll be unlikely to get rid of most of the lines at best
                09-07-2024, 05:50 AM
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
              • Rubenlily
                Samsung QE50Q67TAU - horizontal lines
                by Rubenlily
                First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                I'm no expert but I've done the tape...
                08-16-2023, 01:12 PM
                09-06-2024, 11:40 PM
