Samsung PN50550T Won't Turn On!
    Re: Samsung PN50550T Won't Turn On!
    Diodes are good so there are two likely failures remaining:
    CS808
    or
    ICS801, which is probably a surface mount device on the bottom of the board.
    Does your multimeter have a capacitance test function?
    • coppercitycomputer
      • Apr 2014
      • 90
      Yes but I don't know how to use it! I found both parts ICS801 is a SMC chip underneath. And CS808 looks like a AC safety cap.
        Can you show us a picture of your meter?
          • Apr 2014
          • 90
          Its a Craftsman 82175 and for caps it has 400NF or 4NF, I don't what setting to use.
          http://ecx.images-amazon.com/images/...8L._SS500_.jpg
            Use the 400nF range. Remove the capacitor from the board before testing it.
              • Apr 2014
              • 90
              testing the cap after unsoldering dose not budge my meter, it just keeps reading 0. On the continuity test it reads 1
                Looks like the capacitor is bad, then... I would replace it.
                http://www.digikey.com/product-detai...0492-ND/269112
                While you are at it, you could add the IC, just in case it is bad too:
                http://www.digikey.com/product-detai...6-5-ND/1981061
                to save on potential shipping costs.
                  Before you order, have you got any known good capacitors to check on your meter first, for example a 100nF capacitor?
                    • Apr 2014
                    • 90
                    A new .1uf test at 100-104 so the meter is working.
                    Thanks very much for your help, I will order that and the IC and post back.
                      • Apr 2014
                      • 90
                      Quick Question, I have .0068uf Metalized Poly Fim caps but they are 630V, can I put two of them in there to make 1.2KV?
                        • Apr 2014
                        • 90
                        I went ahead and did it anyways two .0068UF 630V end to end, and stuck it in there for a quick test same problem as before.
                          0.068uF end-to-end is 0.034uF total (caps in series reduce value like parallel resistors), and 0.0068uF is too small.
                          It could be that IC, too; but the cap should definitely not test that low.
                          Note that these converters are usually quite critical about the capacitance, a drop of 20% can throw them out of their operating band.
                            • Apr 2014
                            • 90
                            So would two .1 work? Two end to end?
                              • Apr 2014
                              • 90
                              Two .1's end to end and a .01 on one side., the TV fires up and works just fine. Is that safe to leave in there or should I still order the right part?
                                You should really use the right part, it'll cost you about $5... Bodges like that can go wrong or become a fire hazard if incorrect components are used.
                                Good to hear though. You do not need to order the IC. Only the capacitor.
                                  • Apr 2014
                                  • 90
                                  Got the parts in today, solder them in and button back up the TV. The TV is working really well, watched it for several hours tonight.
                                  Thanks Tom very much for the help, I could have not done without you and everyone here.
                                  Anyone’s guess on how long this set will last? Samsung Plasma from late 2009. Thinking of storing away my new LG LED 42" and using this plasma. What would you guys do? The picture is about the same in my eyes.
                                    • Apr 2014
                                    • 90
                                    Just a quick question, Anyone’s guess on how long this set will last? Samsung Plasma from late 2009. Thinking of storing away my new LG LED 42" and using this plasma. What would you guys do? The picture is about the same in my eyes.
                                    • Ryckmav
                                      • May 2014
                                      • 45
                                      • Ryckmav
                                        • May 2014
                                        • 45
                                        dam all I wrote above is gone! what wrong with this forum?
                                        ok pic above was to explain;
                                        mine went dead totally (pn55b550t2f)
                                        remote is fine
                                        all 4 fuse ok
                                        capacitors seem ok but I heard they could be too weak and cause other stuff to overheat?
                                        all I can see is this suppressor pcx2337 with some good on it (or this is silicone to stop vibration?)
                                        any clue?
                                          Originally posted by coppercitycomputer
                                          Just a quick question, Anyone's guess on how long this set will last? Samsung Plasma from late 2009. Thinking of storing away my new LG LED 42" and using this plasma. What would you guys do? The picture is about the same in my eyes.
                                          A lot longer than any LED TV for sure.
                                          Pic may look the same in a lit room... you need to have a dark room to benefit from plasma.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
