Samsung PN50550T Won't Turn On!
    Re: Samsung PN50550T Won't Turn On!
    That's very odd...
    Can you try the test again, but with the resistors/wire in the main board connector instead?
    • coppercitycomputer
      • Apr 2014
      • 90
      There is no VS-On to the input/main board, only PS-On shorting that to ground has no effect.
        Well, something is not right. If you do that jumpering, you SHOULD get a relay click. I'm not able to explain why you do not. Can you check the voltage on the VSON and PSON with the resistors installed?
          • Apr 2014
          • 90
          Ok I went back to the drawing board ;-)
          With VSon 100Ohm to 5.3V and PS-On grounded to chassie and main/input board uplugged and controller unplugged. I get a loud click then a 2nd more quite one.
          Ok hopeful that's right, what's next?
            OK, that's better. Now, in that configuration, do you get Va & Va voltages? If not, do they come back with X- and Y-main disconnected?
              • Apr 2014
              • 90
              Ok with the X and Y connected, the power supply clicks on then clicks off, voltage's fall, With the X and Y Removed the power supply clicks but dose not click off and I hear whine but the voltage still falls.
                Does it rise at all? Or not?
                  • Apr 2014
                  • 90
                  The voltage go's higher with the X and Y unplugged about 15 volts and 5 volts, with the X and Y plugged up it's only makes it to about 8 volts. Then they fall off after few secs. regardless of the X and Y being plugged or not!
                    • Apr 2014
                    • 90
                    What should I do next?
                      It seems the power board is not working properly.
                        • Apr 2014
                        • 90
                        Any way to test the power board and replace compents or just replace it?
                          There are a few tests. Can you read off the BN44 number on the power board?
                            • Apr 2014
                            • 90
                            BN44-00274A. Should I remove the power board?
                              Not for now. Will try & find schematic.
                                Top result:-
                                http://www.tgohome.com/ServiceManual...&Search=Submit
                                Board JUMPERED ON (measure after two relay clicks - CAREFUL PRIMARY SIDE - HIGH VOLTAGE):
                                - voltage across: any of CP801/CP802/CP803 - about 390V
                                - voltage across: CQ815, CQ807, CB803, CS847, CS846 (if present)
                                Check the following for short circuits, may be done with board installed or removed:
                                - DS825
                                - DS824
                                - DS801
                                - DS800
                                  • Apr 2014
                                  • 90
                                  Don't know how read it or if it's the right sheet but would this help?
                                    See above, already linked.
                                      • Apr 2014
                                      • 90
                                      All of CP801 CP802 and CP803 have 390V Voltages from CQ815 (19.8V), CQ807 (13V), CB803(16V), CS847 (15V), CS846 (if present) Not found.
                                      Are these rectifiers and how do I test them?
                                      - DS825
                                      - DS824
                                      - DS801
                                      - DS800
                                        Please reconfirm CQ807 voltage, it should be about 15V.
                                        They are diodes/rectifiers yes. For the diodes, you should take the red and black probes and put them across all three combinations of pins. Mentally number the pins 1 thru 3. Order does not matter just be consistent between each device. Test 1-2, 1-3, 2-1, 2-3, 3-1, 3-2 (Red-Black) and note reading for each. I am expecting shorts for some combinations due to them being in circuit - this is OK.
                                          • Apr 2014
                                          • 90
                                          The CQ807 voltage is 15v! 1 is unlimited on my meter 0 is shorted. I did not find DS800.
                                          Red on Pin 1, Black Pin 2 DS824 1 DS825 414 DS801 1
                                          Red on pin 2 Black On Pin 1 DS824 420 DS825 1 DS801 1
                                          Black Pin 2 Red pin 3 DS824 1 DS825 414 DS801 454
                                          Red Pin 2 Black Pin 3 DS824 419 DS825 1 DS801 1
                                          Hope that is right! That is with the low voltage side towards me, AC input in the upper right corner
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
