Pioneer PDP-6010 FD vertical half bar
    Hi experts, just got a 2007 model PDP-6010 FD and found a vertical bar that came with it. Bar is from the bottom and carries half way up screen. It is 14" from the right screen side and is 3 3/8" wide. no colors, totally black. Other than that little thing the picture looks perfect. Any suggestions ??? I'm a new guy so i don't think I can post a picture yet:
    Last edited by bebee; 04-01-2014, 02:01 PM. Reason: Didn't think I could attach a pix, surprise!
    Re: Pioneer PDP-6010 FD vertical half bar
    A wide bar indicates a possibly loose connector or bad control board.
      Unreal, I've never posted anything anywhere before. So I guess I'll undo a bunch of screws and take the back off this thing. I'll try the easiest thing first I guess, poke around and see if I find anything that looks loose or not obviously right. Is it ok to crank it back up to see if it sorta fixed itself with the back off or do I have to put it back on again. I f that doesn't work, what board (s) should I be looking for. Thanks a bunch for an answer.
        I got a pdp6020 and it has circuit boards all around the tv. I bet its a bad connection to the board that goes to the tab. I counted how many boards there were in the tv and I counted 20. Let me know the board number I still have the boards.
          DO NOT run this tv with the back off without finding a way to hold down the Tamper Switch or you will be adding to your headaches.
            That black bar COULD be a bad panel, I misread your description and thought it was one third of the screen.
            But doesn't hurt to check connectors.
              Yea either a bad panel or connection at the ribbon cable or the circuit board connecting the ribbon cable to the panel.
                Thanks for all the rapid responses guys, I am overwhelmed. I think i found the motherlode of help here and am really grateful for the responses. You are all much faster than i will be able to be in getting to this. I will have to start this weekend when I have some quality time to get in to this project as i am a total beginner. I think I have to work slowly and take a lot of pix so I can put it all back together properly. I will report back Sunday or so. Again thanks !
                  Yes do take pics or you will have a bag of parts left over lol. And remember the trap switch !!!
