Panasonic Plasma TV 14 Blink Code Explained Repair for 2011 Panasonic Plasma TV
  • tw2005
    • Oct 2011
    • 6458
    I was told about this video in another thread so I thought I'd highlight it as an example of what NOT to do in the first instance.
    The procedure is straight out of the panasonic guide for this series which appears SJ has used for the fault finding process.
    Unfortunately if you follow this without checking for shorted Vsus or bad SC then as you will see by comments already you'll end up replacing the A and the P boards and still be wondering why the 14blinks is not solved.
    Have a read of the attachment first, then watch the video.
    Shopjimmy.com
    http://youtu.be/d_9SOlcfhcg
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TV 14 Blink Code Explained Repair for 2011 Panasonic Plasma TV
    Slow progress, but SJ has now added a note. Still trying to get them to make it better with checking for shorts.
    • otts32
      • Oct 2014
      Looks like they have posted a new video for the panasonic 14 blink code: https://www.youtube.com/watch?v=iHBIiRxhe0w
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        I have one of these horrors at the moment. First thing I did was check for shorts on SN--Of which there were several!
        I'm currently waiting for a so-called, repair-kit and some extra IGBT's
        TELEFIX
        • tw2005
          • Oct 2011
          • 6458
          better but the best place to get advice is here. at least we'll try to help as opposed to SJ. You should read one comment where they told a guy if he did not know how to use his meter then he had not followed step 1.
          This is the risk when you start providing video tutorials, not everyone is going to be able to interpret the results and not every result will be the same when a board fails.
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • rmacintosh
            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
            by rmacintosh
            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
            The symptoms of the tv ar as follows:
            • Plug AC in to back of TV
            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
            • The 3 blink code is given by the power LED
            • If the TV is unplugged and then
            03-14-2020, 12:24 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • orbit417
            Panasonic Plasma tc-p55vt50 6 blink error code
            by orbit417
            Hi All,
            Thank you in advance for your advice.
            I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
            I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
            I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
            04-14-2021, 09:11 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
