Samsung LN46A500T1F Color Distortion problem
  • inb4tehlulz
    • May 2014
    • US
    #61
    Re: Samsung LN46A500T1F Color Distortion problem
    Also, how do these ribbon cables work? They look like the tabs should be squeezed, but no amount of gentle pressure seemed to move them and I don't really want to break them experimenting.
    • LN-46-A-500
      • Oct 2014
      • 6
      • Puerto Rico
      #62
      Hello
      In need for some advice: got this same problem (solarization picture color) need to identify either is IC or Tcom. Have not opened it yet. Tried the first usual suspects:
      1. Picture diagnostic test
      2. Factory reset
      3. Firmware upgrade? (Haven't found where to obtain it)
      Have some pictures but I'm on a mobile device and have bad time trying to upload as attachments so I uploaded them to a shared folder, here:https://www.dropbox.com/sh/791317y81...8Mcg0HXqa?dl=0
      Any reply about this it will be really appreciated.
      Best regards
        I would check the DC GAMMA Voltages at the test points on the T-CON board.
        • LN-46-A-500
          • Oct 2014
          • 6
          • Puerto Rico
          #64
          Thanks flr the reply: will try to do that, however I think Im looking for a spare, compatible t-con board to test if is that part then find/buy a new/used one.
          • LN-46-A-500
            • Oct 2014
            • 6
            • Puerto Rico
            #65
            Hello, I'm waiting for a replacement board. Meantime I need to found one or more of the clipping that attach the two ribbon cables. Pics for clicks:
              I don't think you can buy those separately - you have to buy a whole new T-con board.
              • LN-46-A-500
                • Oct 2014
                • 6
                • Puerto Rico
                #67
                Right. I'm ordering a new board. But it does include new ribbon retainers (the brown stuff there that hold down the ribbon contacts) I mean if then OK I should be more careful removing them. Just didnt figured out and accidentally broke one retainer (or it just was toast due to age / heat and when I forced out just came apart) anyhow, I'm waiting for the seller to confirm that have the board on stock and if they can issue the broken retainers (or how they're named). Any reference on how to successfully put them back on a new board? Hope I can fix this HDTV. Can't afford a new TV right now or on the next months, maybe years.
                • LN-46-A-500
                  • Oct 2014
                  • 6
                  • Puerto Rico
                  #68
                  Yes! After two months the new board finally arrived. Hopefully had the ribbon 90° clips with it so replacement was easy. Turned on and everything seems right, no more solarized colors. I'm testing the board watching a couple Premier League matches. I thank you all for the help. If I did not found this forum I was lost with a non working HDTV. Thanks
                    Thanks for the repair follow-up.
                    • hiroo
                      • May 2015
                      • 14
                      My Samsung LN46A500T1FXZA has developed this color distortion:
                      I measured the voltages on my TCON board: (These are referenced to the large copper sections on the corner, which I took to be ground.)
                      1 15.17
                      2 13.05
                      3 12.22
                      4 11.34
                      5 10.93
                      6 10.55
                      7 10.1
                      8 9.47
                      9 8.88
                      10 6.02
                      11 2.65
                      12 5.03
                      13 4.84
                      14 4.58
                      15 4.19
                      16 3.32
                      17 2.5
                      Any recommendations on whether these voltages are the cause and whether changing out the chip would help?
                      Pictures of the board and chip:
                        Bad GAMMA IC AS19 (same common failure as AS15).
                        • hiroo
                          • May 2015
                          • 14
                          I ordered an AS19 replacement chip but noticed that repair kits advertised for this problem/board also include a surface mount fuse and resistor. Are those usually necessary?
                            No, not unless all voltages are nearly zero, which is a very uncommon fault.
                            • hiroo
                              • May 2015
                              • 14
                              Ok, I had problems with pads lifting as well. I lost 6 pads in the process. (Should have had more patience with the heat gun)
                              Anybody think this is worth trying to jumper all those connections? The three adjacent pins seem pretty difficult given how small these pins are.
                              What kind of wire is good for this sort of thing? Any tips on how to solder wire to a pin with only two hands?
                              There is also a stubborn solder-bridge between two pins (4 and 5 from the bottom on the right side) that I can't get out using solder wick. Any advice on that?
                              • laxdad
                                • Jul 2015
                                • 4
                                Hey guys, I have a Samsung LN46A500T1FXZA and I believe the Tcon board is bad. Below are the readings I've taken after reading a few posts. The part number of the Tcon board is V520H1-C06. I've gone ahead and checked out jimmyshop and I don't see them getting the part in any time soon. /:
                                T1 15.15
                                T2 13.27
                                T3 12.38
                                T4 11.85
                                T5 11.51
                                T6 11.9
                                T7 12.52
                                T8 9.96
                                T9 9.97
                                T10 6.37
                                T11 6.91
                                T12 5.61
                                T13 4.98
                                T14 4.69
                                T15 4.37
                                T16 3.79
                                T17 3.12
                                Can someone please verify whether or not my Tcon board is bad please?
                                  It is bad.
                                  • laxdad
                                    • Jul 2015
                                    • 4
                                    Thanks Bud! Any suggestions where I should buy my replacement by chance?
                                      The T-CON board or the IC? I get my IC from EBAY, or replacement boards/ICs from shopjimmy.
                                      • laxdad
                                        • Jul 2015
                                        • 4
                                        The board. Im trying to avoid long down times as I know I'd jack up the repair.
                                        • matt526
                                          • Nov 2013
                                          same TV here with a very dim picture and
                                          My T-Con voltage is: I think it looks good but not sure.
                                          Volt 1 -12.65
                                          Volt 2 -12.65
                                          Volt 3-12.64
                                          Volt 4 -12.64
                                          Volt 5 -12.65
                                          Volt 6 -12.63
                                          Volt 7 -12.63
                                          Volt 8 -12.62
                                          Volt 9 -12.62
                                          Volt 10 - 13.91
                                          Volt 11-13.90
                                          Volt 12-13.89
                                          Volt 13-13.90
                                          Volt 14-13.90
                                          Volt 15-13.90
                                          Volt 16-13.92
                                          Volt 17-14.08
                                          Volt 18??19.27
                                          maybe it could be the Backlight Inverters. Any idea on how to test those and what volage I should be getting?
                                            09-07-2024, 05:50 AM
                                          • StromarMiki
                                            Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
                                            by StromarMiki
                                            Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help....
                                            11-06-2021, 06:32 AM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
