Samsung LN46A500T1F Color Distortion problem
  • "AD"
    • Mar 2014
    • 37
    Re: Samsung LN46A500T1F Color Distortion problem
    Ahhh! perfect! Thank you. I'll post my results once I get it done.
    Regards,
    AD
    • "AD"
      • Mar 2014
      • 37
      Hi guys,
      I received my IC yesterday, but I'm afraid removing the old one is not going well...I bought that chip quick removal kit, but the IC didn't move. So, as careful as I could, I use the fine tip of my iron to disorder and lift up every leg of the IC, I think I damaged one or 2 pads. Anyway...even with all 48 legs totally off the board, it still does not come off. How do you remove those things??
      At this point I'm probably going to have to just buy the T-con itself, right?
      AD,
        It is possible the IC could be soldered from underneath. Hot air is really the only way to easily remove these, if they have a pad.
        • "AD"
          • Mar 2014
          • 37
          ohh boy...I have a heat gun, but I'm not sure is appropriate for electronics, I might heat up a few inches around the IC and probably overheat other components. I'll browse around and see if I can find a T-con. shopjimmy.com doesn't have it for now.
          Thanks Tom!
          AD
          • Glitcher
            • Mar 2013
            • 673
            • USa
            What I do is I put aluminum foil around the tcon board and cut a hole where the chip is. Usually 30 seconds to a minute with a heat gun and it should come off.
            If it is soldered to a pad, there are usually little holes on the opposite side that you can solder to heat it up faster also.
            • "AD"
              • Mar 2014
              • 37
              Thanks for the advice Glitcher, I will try that tomorrow and see if I can get it off.
              AD
              • "AD"
                • Mar 2014
                • 37
                So.... Bad news.. Before I could succeed getting the IC of the broad, I got a Tcon replacement, and I put it in, but the TV still looks like crap. Unless the Tcon replacement is messed up exactly in the same way mine was, I think it could be something else. Any ideas?
                AD
                  The way to check would be to make those gamma measurements again.
                  Just recently, picked up a 37" Sony with a gamma problem, which is actually my first. I haven't done one before. Should be a good subject for a video.
                  • "AD"
                    • Mar 2014
                    • 37
                    OK... first of, please let me know if I'm understanding the numbers correctly according to the picture bellow... Is that the right order?
                    If so.... here are the values.
                    Volt 1 15.1
                    Volt 2 12.9
                    Volt 3 12.1
                    Volt 4 11.32
                    Volt 5 10.92
                    Volt 6 10.6
                    Volt 7 10.47
                    Volt 8 12.61
                    Volt 9 9.23
                    Volt 10 6.43
                    Volt 11 6.1
                    Volt 12 4.46
                    Volt 13 6.77
                    Volt 14 7.52
                    Volt 15 5.78
                    Volt 16 7.93
                    Volt 17 3.2
                    AD
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      #30
                      From the voltages, looks like another bad tcon..
                      A lot of tcons are commonly misdiagnosed as coming from a "bad panel" so I wouldn't be surprised. It has happened to me before also.
                      They see something wrong with the picture, assume its a bad panel, and assume all the parts inside are good, working, and Then labeled as tested.
                      • "AD"
                        • Mar 2014
                        • 37
                        Did I interpret properly the numbers arrangement?
                        AD
                          Yep, you interpreted it correctly, and right there's another bad t-con. So yeah, did they claim to test it? They probably didn't...
                          • "AD"
                            • Mar 2014
                            • 37
                            they sure did... with "100% money back" if something was wrong, but I still gotta pay the shipping back though. I was wondering, could it be something on my TV that is making Tcons go bad?
                            AD
                              Failure rate of these T-cons with AS15 or AS19 IC is incredibly high.
                              Nothing wrong with your panel if picture is OK aside from colours. Seems swapping boards is often ineffective due to the high failure rate.
                              • "AD"
                                • Mar 2014
                                • 37
                                that takes me back to the work bench then...I'll go back to try to get the chip off the original board. After all I have already the new chip here.
                                Thanks Tom,
                                • mniemi
                                  • Apr 2014
                                  • 8
                                  Hi everyone, I need help with my LN46A500TIF Samsung TV color Distortion as well ... however, I do not have Solarized Distortion. I would like to replace the parts myself if it is feasible.
                                  *I do not have Cable, Use OTA to watch TV, Netflix, Chromecast, & Blue Ray
                                  TV Settings: MUTE 182 Power
                                  - LVDS Out format has to be set at JEIDA.
                                  -- If LVDS is set at PDP or VEGA, the image produces Solarized Distortion.
                                  - TV is set to "Movie" not dynamic.
                                  -- when the TV is set to "Dynamic" the pixels have less distortion.
                                  Color Distortion: using OTA
                                  - On OTA HD channels, there is significantly less noise/distortion of pixels.
                                  - Images with light colors (white,cream, bright blues, yellows, or pastels) do not have pixel issues
                                  - Images with dark colors sometimes have blue speck outlines instead of black
                                  - sometimes images look completely normal (no noise/distortion of pixels)
                                  - On non-HD channels, the black colors are shown as green or red pixel specks.
                                  - Images never look normal
                                  - channels are noisy.
                                  Color Distortion: Using Netflix
                                  - Pixels do not interpret the red color correctly. (displays as pink or orange-ish)
                                  - I do notice kind of a "heart-beat" in the pixels.
                                  Visually inspected MB & Power board:
                                  - caps are not bulging
                                  - caps are not leaking
                                  - didn't notice any issues with masking or solder but I'll have to recheck that
                                  - disconnected connector cables to Power board & reconnected to see if that would fix the issue, nope.
                                  - disconnected the connector to the TCON board and reconnected, did not fix issue.
                                  Overall TV Never has these symptoms:
                                  - I do not have any bar lines (vertical or horizontal) on the screen
                                  - I do not have any blocks of missing/empty colors/pixels
                                  - I have not had any problems with my turn turning on/off.
                                  - Audio works fine.
                                  **** Looking online, this problem seems like it could be related to CFLs, TCON, or Power board.
                                  - I was going to take a scope to the caps on the power board but I don't know how I could get a reading off of them the way they are soldered, so I haven't done that yet.
                                  - I was thinking of removing the caps on the power board and checking their capacitance I'd rather do that as last resort to see if something else may fix the issue.
                                  The less distorted picture is an HD channel. The heavily pixelated picture is from a SD channel.
                                  --- I was informed that this maybe a main board issue, if so, can anyone direct me in the correct direction on what I fix. If it's too complicated or not worth it, I'll buy the board. ---
                                  Thank you
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    What firmware do you have?
                                    • mniemi
                                      • Apr 2014
                                      • 8
                                      um, IDK ... I didn't bother to even check that. How do I determine that?
                                      Thank you Shinju.
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        Thank you Shinju.
                                        Service menu or in the TV menu system, scroll down to the gear icon/ select SW update and hit the info button on the remote.
                                        I am not saying it will fix it, but one of the first Sammy's I did after a cap job had artifacts in the screen after power up. I did a quick firmware search on Google and found that Samsung had one that was a two part install, one for the main processor the other was for the co processor. After doing the 2 part firmware upgrade the picture didn't have artifacts but instead looked like it was on acid (not solarized) I was like SHIT, made it worse but after another 10 minutes of research others ran into this too. It ended up changing the LV settings from VESA to JEITA (this was a known bug with Samsung's firmware for that panel) so all I had to do was go change it back and poof it was back to normal no issues.
                                        I am still using this same Panel today in our rec room so far its been perfect.
                                        Make sure to follow the instructions perfectly, your issue look like the Toshiba I have that ended up being a color correction in the service menu tweak and didn't need any parts.
                                        Right now I have another Sammy 37 inch that's got serious gamma,ghosting and picture retention issues due to a bad t-con!
                                        • mniemi
                                          • Apr 2014
                                          • 8
                                          I did do a software update and that did not fix my problem. I also have my TV in JEITA format due to the other two formats causing solarized distortion. However, I do not how to verify what software was installed onto the TV. Does anyone know how I can find that out?
                                            09-07-2024, 05:50 AM
                                          • StromarMiki
                                            Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
                                            by StromarMiki
                                            Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help....
                                            11-06-2021, 06:32 AM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
