Samsung LN46A500T1F Color Distortion problem
    Re: Samsung LN46A500T1F Color Distortion problem
    They do not look right, not ALL of them should be > 10V. 19V is also very high, never seen one with Voltages that high.
    You have bad T-CON.
    • JOHNFROMRI
      • Dec 2018
      I have this same tv but it has horizontal black lines that scroll and flicker? Do you think that is the same board?
      • noledud
        • Dec 2013
        • 413
        • united kingdom
        #83
        Talking of replacing boards - I always repair and replace AS15 / AS19 chips because my theory is at least you know its 100% working with no compatibility issues.
        for those that cant replace the chips there are services on ebay for TCON repair here in the UK so imagine other countries have people offering similar services.
          09-07-2024, 05:50 AM
        • StromarMiki
          Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
          by StromarMiki
          Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help....
          11-06-2021, 06:32 AM
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
        • alro7779
          Samsung UN55MU6103F video problem; has colored stripes on the display
          by alro7779
          Hello, everyone!
          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
          09-27-2025, 11:29 PM
          09-06-2024, 11:40 PM
