What is this????
  • Evenflow
    • Mar 2014
    • 38
    • US
    What is this????
    Why have they jumped these points and added FET to the bottom of my new x-main????
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: What is this????
    I'm guessing it came from a Samsung panel? I had the same board, its a revision for a later version I guess.
    • Evenflow
      • Mar 2014
      • 38
      • US
      Yes..Well Insignia, same thing. Old one did not have those jumps ect. But TV works
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • novator2007
        Help with finding ThinkPad T460 JTAG Points
        by novator2007
        Hello All,
        I got a T460 with issue - No picture - Fan on full Speed and no Power LED Light.
        Bios already reflashed
        All standard voltage is present. CPU on emergeny(?) mode - max 30 c Grad.
        By Schematc & BRD View I have found few Debug/Jtag points.
        Just not sure which one is correct,
        1.There is some(under lack) Test points near CPU - Schematic Page 6
        2. J9 26p place for connector - Present: PCH_TMS/TDI/TDO/TCK/RSMRST
        3. J8 26p place for Connector - XDP_TMS/TDI/TDO/TCK/RSMRST
        I trying to find a correct...
        08-02-2022, 07:49 AM
      • Fly_Among_Stars
        VIZIO E70-E3 Half picture with half TCON
        by Fly_Among_Stars
        I have a VIZIO E70-E3.
        Symptoms: Black screen, no picture, but LED backlights are working.
        I probed the power board and voltages are as listed on the board.
        Main board appears fine, too.
        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
        There are two separate ribbon cables feeding the LCD.
        If both are connected, the screen is black.
        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
        04-24-2023, 08:20 PM
      • lmcancu
        LED Strip test points and testing?
        by lmcancu
        Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
        Thanks in advance...
        03-20-2023, 07:52 AM
      • migax miranda
        hp 15s-eq0012np contact points on the "type C" charger input were torn off
        by migax miranda
        Hello, a "hp 15s-eq0012np" arrived to me, the only problem with it is that the contact points on the "type C" charger input were torn off. Can anyone tell me what the purpose of each "leg" of the connector is? Which ones are really necessary for it to charge the battery and turn on?
        10-13-2024, 10:03 AM
