Polaroid FLM-323B Powers on, No Picture, Only powers off with cord.
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Re: Polaroid FLM-323B Powers on, No Picture, Only powers off with cord.
    Start back to work today. Will try and figure out how to get to fuse with it all hooked up asap. All the other boards are on a tray over the t-con and the tray fits down over and plugs into a multi-pin stationary socket. Will let you know, Thanks
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Okay Budm. Got the tray proped up and checked fuse at t-con. Getting 5 vdc both sides.
      I went ahead and took out main from tray and found so far two loose connections on 2 caps and another that read good but I replaced it anyway cause one of the leads looked funky. it looked like it was misbuilt. The part that the lead was connected to was on the outside of the bottom the cap instead of inside. Am learning to really pay attention to things.
      • whiz62
        whiz62
        • Dec 2013
        • 242
        • usa
        Ok, got back to this polaroid and got all voltages kickin in and still nothing on screen or sound. took main back off today and reinspected everything. found a surface mount diode that read both ways but different readings so I removed it and it checked ok which is what I expected.
        I took numbers off of main and to me it looks like it is for a 26 or 27" polaroid. The numbers are, 200-107-JK371CH and on a sticker, 899-KC0-GF271XA.
        I got online at shop jimmy and found a 200-17-JK371CH with sticker 899-KC0-GF321XAH and looks identical as far as connections.
        This TV has been jacked around and just wondering if you all think I am on right track and possibly worth the effort. I have $10 in this and the board is $36. Thanks!
        • sergio_av
          Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
          by sergio_av
          Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
          Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
          When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
          Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
          01-01-2025, 05:27 PM
        • KYBOSH
          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
          by KYBOSH
          Saved this beast from the landfill this weekend.
          Manfactured July 2013 in Mexico.
          I love working on plasma TVs.
          Its been a while but I was lucky enough to find 2 this week.
          The TV powers on and stays on but no picture. Havent checked for sound yet.
          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
          Will start troubleshooting tonight.
          10-17-2024, 01:17 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
