Insignia NS-LCD32
  • jstiene
    • Feb 2013
    • 148
    Insignia NS-LCD32
    Hello.
    I recently picked up a Insignia NS-LCD32. When I turn it on, I get sound and also the picture, but the picture will shake continously. It doesn't get worse or better as the TV stays on. Pretty static issue. I was wondering if anyone else has run into this and what the solution was. Checked previous posts but did not see this symptom.
    Joe
  • dcapper
    • Dec 2013
    • 496
    Re: Insignia NS-LCD32
    That is a different problem. Usually it's the cheap power supplies they use.
    Try the old lcd trick. While the tv is on and it's shaking, spray some freeze spray down the sides of the tv and see if it clears up. If it does then the connections to the panel are loose. They are almost impossible to fix.
    On a side not, it could be the T-Con.
    http://www.youtube.com/watch?v=Qj51BkS9d-0
    • srs
      Insignia NS-50DR620NA18 w/ large vertical lines & no picture
      by srs
      I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
      A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
      I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
      04-22-2023, 02:40 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • jose6326
      Insignia Ns-l22x-10a no picture only sound
      by jose6326
      When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
      When i was removing the back cover i heard a rattle.
      Removed the metal plate and the heat sink was off (see pic)
      would this cause a no picture/image issue?
      What is used to put back the heat sink
      07-30-2024, 11:03 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
