LG 42PC1RV - Powers up, sound ok but no picture
  • andyc
    • Nov 2010
    • 14
    • Romania
    Hello!
    I have this LG 42PC1RV Plasma (display type 42V8) that went bad a few days ago. The TV turns on and the sound is working fine but there is no picture on the display. Checked the SCART out and the video signal output is there, channels change, volume control works etc so i'm guessing the main board is OK.
    I took it apart and found that all the fuses for the Ysus and Zsus boards are ok and so are all the voltages from the power supply.
    I checked Va, Vs, Vsc and Vzb and they are all fine, showing very close or exactly the same voltages as labeled on the panel. The only one that is wrong is -Vy. The Y-sus board emits a strange buzz/hiss every second or so and the -Vy voltage goes from 0 or -1 to -2.8V in sync with the buzzing. This also happens when the YDRV board is disconnected. I checked the YDRV input lines and there are no shorts. I think the YDRV board is ok.
    The Va and Vs voltages jump up a few volts when the Y-sus board is disconnected. Is this normal?
    Could this be an IPM related issue? I can't find a schematic for this Y-SUS board and i have no idea where the -Vy supply is generated from and where it goes to (the PCB is multi-layered and i can't trace the connections properly). The IPM looks somewhat different from what i've seen in other people's threads as the parts under it are not exposed. I didn't desloder it so i couldn't see what's written on it (if anything).
    I looked carefully and could not see any sign of blown components or leaked/vented capacitors on any board.
    After being on for about 2-3 minutes the IPM, MOSFETs on the YSUS and ICs on the YDRV board get warm. I can't find anything excessively hot.
    The boards are in this TV are:
    YSUS Model 42V8&X3, part no. 6870QYH005B;
    YDRV Model 42V8, part no. 6870QKE010A;
    ZSUS Model 42V8&X3, part no. 6870QZH004B;
    X-L Model 42V8, part no. 6870QME015A;
    X-R Model 42V8, part no. 6870QSE017A;
    CTRL Model 42V8&X3, part no. 6870QCH0C6C;
    and PSU Sanken 1H328W, part no. 6709900023A.
    This is my first plasma screen repair so any help is much appreciated.
    Thanks,
    Andy.
  • andyc
    • Nov 2010
    • 14
    • Romania
    Re: LG 42PC1RV - Powers up, sound ok but no picture
    Today i removed the flat cable that goes from the YSUS to the Control board and now i get proper -180V -Vy and the YSUS does not make the weird regular buzzing. Could this be a control board issue? Maybe it's not sending the right signals to start the YSUS?
    The control board temperature LEDs do not light up with the flat cable removed so i'm assuming it's powered by 5V from the YSUS.
    I recorded the sound it makes and the varying -Vy voltage measured accross R36:
    https://www.youtube.com/watch?v=oy7bYYbWvVM
    Hope you can hear it, youtube compression dulled the audio a little.
    I think the noise comes from one of the little transformers on either the "setup" or "setdn" daughterboards but i can't tell wich one (the blue and yellow ones in the attached picture).
    • dcapper
      • Dec 2013
      • 496
      I repaired 2 LG's with those symptoms. Both were the YSUS board. Not saying that is your problem but here is a question. Leave the tv running for a bit and touch the big heatsinks on the YSUS and ZSUS. I see you checked them but were any cold?
      • charles frost
        FROSTY
        • Mar 2014
        • 18
        Yea bud bad Y sus. Be advised there could be bad buffers also. Not all the time. At least check buffers, top and bottom for any burned ICs or small holes in them.
        • andyc
          • Nov 2010
          • 14
          • Romania
          @dcapper I let it run for about ten minutes and both the YSUS and ZSUS IPM heatsinks become warm. I don't know how hot they should get during normal operation...
          @charles frost I checked the buffers board (there is only one large board with 6 buffer ICs in this TV) and there are no shorts between the input and output pins and the inputs (two of them, one for 3 buffer chips) show up as diodes like i read on the forums that they should.
          I also put a scope on the pin labeled "waveform" on the buffer board and this is what it shows when the tv powers up:
          https://www.youtube.com/watch?v=Su8TgXIwdhY
          • andyc
            • Nov 2010
            • 14
            • Romania
            Hello again!
            I had some extra time over the weekend and i did some further research and tracing of the Y-SUS. Turns out the two daugtherboards are the power supplies in charge of generating -Vy and Vsc and they take power directly from the Vs line. The left one (blue transformer) is for Vsc (even though the resistor across which we measure -Vy is right below it) and the one with the yellow transformer is for -Vy. The yellow one was buzzing. So since they are powered by Vs and that voltage was nice and stable, i concluded that te problem must be something shorted on the output of the -Vy module. I traced the problem down to one of the MOSFETs on the smaller heatsink. There were 3 of them in parallel that showed some strange readouts on the meter so i removed them for proper testing. The defective transistor was not shorted but showed a weird small resistance across two of it's pins. I've attached a picture of the culprit.
            I bought a replacement and now the TV came to life and works great. Good picture too! The panel seems to have some life left in it despite the age of the TV.
            Thanks for helping!
            Regards,
            Andy.
            • legg
              LG 42PC3 buffer output doesn't follow YSUS
              by legg
              LG42PC3D -UD originally with green lamp but no display or audio.
              Owner says was working, then went 'pop'.
              All 5V caps bulging. replaced.
              All PSU output voltages within spec but -Vy is low on YSUS.
              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
              eventually shorts DG. Replaced all 3 - -Vy now OK.
              Y scan buffer test point does not follow YSUS output below -50V
              Note: This unit seems to expect YSUS output to park at -Vy in between
              drive signal pattern periods. A replacement drive signal board confirms this....
              11-18-2021, 11:49 AM
            • malogro
              Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
              by malogro
              Hello all,
              I'm stumped on this guy, so wanted to see if anyone has any further ideas:
              Intro:
              This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
              Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
              04-14-2023, 04:44 PM
            • jose6326
              Samsung s32d850t powers off
              by jose6326
              Powers on as normal shows an image then powers off after 10 seconds
              I have to unplug it from the wall and replug to get it to turn back on but then shuts off
              No blown caps
              I searched for this model but nothing comes up...
              11-29-2024, 11:21 PM
            • Truncatedhose
              Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
              by Truncatedhose
              Greetings all!
              Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
              Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
              07-04-2018, 10:59 AM
            • Rekoo1997
              DELL Precision 3520 powers on automatically
              by Rekoo1997
              Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
              Issue: The laptop powers on automatically after being shut down.
              Actions Taken by Technician:
              BIOS reflashed
              Intel ME region cleared
              Result: Issue still persists
              Additional Observations:
              Power button reads 3.3V (normal)
              The problem occurs both when running on battery and when connected to AC adapter...
              08-07-2025, 08:48 AM
