Re: Samsung LE40R87BD LCD TV - relay clicking repeatedly but wont start
  • sordids999
    • May 2013
    • 2161
    Ok so noticed on the psu that there was two bulged caps changed them but the tv still clicks but won't boot up
    Any ideas
    Needs an EEPROM reset, probably. There's info on this forum about jumpering pins 5 and 6 to accomplish the reset.
    • vinceroger69
      • Mar 2012
      • 6714
      this may help try at your own risk!!! found on another forum im a member of
      For anyone with the same problem the procedure is as follows.
      On this model the eeprom in question is IC 1803 (24C256) 8 pin smd and is located on the underside of the main board near the common interface. The clock and data pins are pins 5 and 6 and are identifiable by the 100 ohm smd resistors connected to each of them. Fit a shorting link (on long wires) between the pins. Reassemble the chassis. Switch on and then remove the short. Bring the set out of standby. Now access the service mode as follows-
      Using the remote control, switch to standby, press info, menu, mute and power. The set should start and display the service menu. Using scroll keys select item 8 and enter by scrolling right. Select "tuner" and set to auto. Revert to previous screen by pressing menu. Now scroll to "reset" and enter by scrolling right. The set will revert to standby. Power back on and tune in stations.
      • Dang
        • Aug 2013
        • 440
        As above but I found the time from powering on to removing the pin short is critical, I found it to be at exactly 1 second, good luck.
        • sordids999
          • May 2013
          • 2161
          Can someone point me to how to reset the eeprom on this model please
          • vinceroger69
            • Mar 2012
            • 6714
            as per post 3 and 4 this is for your model for a eeprom reset
            • sordids999
              • May 2013
              • 2161
              Oops sorry missed your reply my phone didn't update was replying to toms reply thanks
              • vinceroger69
                • Mar 2012
                • 6714
                its ok mines does the same too at times.
                  09-07-2024, 05:50 AM
                • Journey11
                  Samsung TV won't turn on ... keeps cycling the power relay on & off
                  by Journey11
                  Hi All,
                  First time posting here ... my name is Kevin but my friends call me Journey.
                  I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                  After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                  It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                  07-04-2024, 02:44 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
