Panasonic Plasma has weird red/green sparkles
  • taiwwa
    • Dec 2013
    • 10
    A few months ago there was an electrical storm and the main board was fried. I replaced it.
    Have tried 3 different power supplies. All exhibit same problem. Power supply is not the problem.
    What is?
    Re: Panasonic Plasma has weird red/green sparkles
    Does it appear on all sources? I've had this problem before and it was caused by a loose HDMI/DVI cable. On my computer monitor. Exact same random green pixels at certain points in the image.
    • taiwwa
      • Dec 2013
      • 10
      This is on component (nintendo wii)
      It is visible on playstation 3 blu ray, though not as prominent.
      • taiwwa
        • Dec 2013
        • 10
        I really wish that it was a case of bad connections.
        But after replacing hdmi cables and rca cables, it still exists.
        • taiwwa
          • Dec 2013
          • 10
          So I'm thinking it's a ysustain problem.
          I should also replace the z board too?
          • taiwwa
            • Dec 2013
            • 10
            intuitively, I have the feeling that hte problem is the y-sustain buffer. That is because it appears to me that the y and z are working fine, but that there's some problem in translation.
            • taiwwa
              • Dec 2013
              • 10
              Good news!
              I solved it.
              the Wii console was defective somehow.
              And apparently I have a ps3 that has problems as well.
              This is a huge relief!
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                I happened several times, in the search for help from the web, to consult this very interesting forum.
                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                Having said that I come to the gist of my post on the forum as the title suggests.
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • LITEZONER
                Panasonic TH-65PF9UK 65" plasma display weird issue
                by LITEZONER
                forgot to put the model number in the last post, could not edit it, guess I waited to long. anyway, has anyone seen this weird issue on one of these plasma sets, I was thinking maybe a loose ribbon, but wanted to check if anyone had seen this before. thank you...
                10-22-2021, 09:27 PM
              • Lintesir
                Panasonic P42S30 Plasma - Pink sparkles
                by Lintesir
                My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                There is about a 5cm high region at the top without any sparkles,...
                07-26-2024, 03:16 AM
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
