40bv700b lcd main board fault?
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    Hi all. I have the above tv, it works fine until you plug in a hdmi.
    When you do the picture vanishes leaving only the sound. the backight is still on but the picture s black. would replacing the main board fix this?
    would a psu fault cause this? when the hdmi is unplugged the tv works as normal again, ps the sky box and hdmi wires are fine.
    thanks for reading
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    Re: 40bv700b lcd main board fault?
    nobody have any idea? im not wanna get a new main board if a psu could cause this problem?
    im gonna try find a factory reset maybe help?
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      ok i done a reset from the service menu and all seems to be good so far, Menu 4725 brings up the menu as its vistal based main board.
      hope thats it sorted
        Toshiba 40BV700B? It's completely, 100% Vestel, not a lick of Toshiba aside from one patent for the TV guide which Vestel bought off them.
        • charlierfc
          • Mar 2013
          • 93
          • scotland
          hi tom, have you seen this before where a reset of the tv cured the fault? so far 3 hours alls been good. any faults id update for others, bit of luck and its cured. vestel are pretty rubbish main boards psu no wonder they rebrand the tvs
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • advant
            by advant
            02-03-2020, 12:25 AM
