LG EAY57681601 power supply diode
  • Driver8
    • Aug 2013
    • Usa
    This is on the power supply/backlight inverter board EAY57681601 for LG 47LH40-UA television. The supply failed when commanded from standby to run, taking out the main fuse. I'm trying to identify diode D601 in the inverter section where the package was blown apart and the markings are gone. Q601 and Q602 will need to be replaced also. If anyone can point me to a schematic that would be most helpful. Also would like to hear if anyone has repaired this type of failure before.
  • R_J
    • Jun 2012
    • 9581
    What are Q601 & Q602? D601 might be a STTH10LCD06FP, I don't have this schematic
    Check all the components in the gate drive of the mosfets there are two resistors from source to ground, are they both ok?
    • Driver8
      • Aug 2013
      • Usa
      Thanks for the info! Q601 and 602 are TK12J60U, a 12A 600V MOSFET. They are run in parallel, but one shows shorted gate to source, the other about 2K. Both read about 2 ohms drain to source, so at least one is shorted. The gate to source resistors are 10K and look ok with a microscope. On your question, the source terminals are commoned but there are two 0.2 ohm resistors in parallel from there to ground that are intact. I had to lift one end to check them. Gate circuits look OK, plausible junction drops in both directions on the gate drive/clamp circuits. Resistors measure as marked. Bridge rectifier OK.
      On the fast recovery diode suggestion, that part looks plausible for the position, except that the original was in a standard TO220 with a silpad insulating it, not an insulated package. The leadframe had the center lead joined per the attached photo.​ Interesting that the board was laid out to have another diode in parallel with this one, like one isn't enough for some cases.
      This TV does not have a lot of hours on it in spite of being old. I'm wondering if a line transient set this up for failure.
      • R_J
        • Jun 2012
        • 9581
        A few lg power supplies used a IDT02S60C but I might go with a IDT10S60C
        If you were the first person to open the tv the top of the diode will still be there somewhere
        • Driver8
          • Aug 2013
          • Usa
          I can't believe I found it! Of course I had looked before everywhere inside the TV but no luck. It was actually lying under where the TV was mounted. Since it was wall mounted, there was a hole in the case where the base mount used to be. Must have ricocheted around until it found the hole.
          Photo is attached - you pretty much nailed the part number: D02S60C. Thanks again.
          • R_J
            • Jun 2012
            • 9581
            If you can't find it, Infineon replacement is IDH04G65C5
            IDH04G65C5XKSA2
            • Driver8
              • Aug 2013
              • Usa
              Success! Replaced the failed parts and it is back in service. It's run for an hour so I'm going to declare victory. Here are the part substitutions in case anyone needs to fix the same problem.
              Failed Replacement
              Diode D02S60C IDH04G65C5XKSA2
              MOSFET TK12J60U STW18N60DM2
              8 Amp slo blow fuse Littelfuse 0477008.MXEP
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
                07-01-2024, 06:34 AM
