Issue with 42 Vizio TV
+ More Options
Posts
  • derrickcaputo
    • Aug 2024
    I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
    detected the TV model but no image.
    Is there anyone having the same issue? Did you find any solution?
    • 12206
    • U.S.
    What's the full model number? should be on back cover.
      • 12206
      • U.S.
      Try a simple reset, unplug tv, hold power button on tv down for 30 seconds, retry it.
        • 12206
        • U.S.
        Did you hook it up like that before and it worked or was that the first time you tried it?
        • EazyBone
          Vizio P759-G1, Tcon issue?
          by EazyBone
          Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
          Any help appreciated
          https://youtu.be/tPeV2Q7TXIQ?feature=shared
          03-22-2024, 03:25 PM
        • remmurdmd
          Vizio E65-E1 strange image issue
          by remmurdmd
          Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
          10-02-2022, 09:12 PM
        • bscottjohnston
          Interesting E60-E3 (Vizio) issue
          by bscottjohnston
          Good morning BadCappers,
          I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
          Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails...
          08-31-2023, 07:41 AM
        • Yanleb
          Vizio M70-D3 4K with dark spots backlight issue
          by Yanleb
          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
          03-22-2022, 01:06 AM
