I have a number of broken flat screen plasma and LED's coming to my place. What boards, besides the power board are worth salvaging for re-sale?
Salvaging Parts
Tags: None
Re: Salvaging Parts
Basicly all the boards. Power Supplies, Main Boards, T-Cons, Control Boards, Inverters,
Y-Sus, Z-Sus. Remote Modules dont fail often. The small Flat leads that jumper between the board are difficult to locate. Recently the addition of the LED backlighting the LED strips may be an option but requires disassembly of the screen to access them. Normally the backlight is considered as part of the screen. When screens are broken or the backlighting fails the TV is toast.. You can break a screen the LEDs are normally still good. -
Re: Salvaging Parts
The bigger Q is how will you know what is good or bad and how will you handle returns?
What do you do when they test the board to find it faulty?
With plasmas, the buffers and drive boards can be damaged if the panel is on when it's cracked.Last edited by tw2005; 03-08-2014, 07:50 PM.Comment
Re: Salvaging Parts
I totally agree, T-CON boards on a crack LCD screen sometime can't be confirm working on a badly smash or crack LCD screen, that had no picture. main board you can try to get sound if you have no picture on a cracked screen, power supply & inverter board should be no problem if the TV power on and stay on.Comment
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
by dclass-proHi all guys, I need your help. On a HP 440 G2 - LA-B181P laptop I was changing the speakers and the pc worked fine everything ok.
After closing it all with all the screws I realized that it would no longer turn on. I opened it and found that the flat cable of the LCD was shorted. I ordered a new flat but the motherboard still won't turn on, as soon as I connect the power supply the connector LED always flashes and the power button stays on.
I tried to check the voltages and the 3v and 5v are there, on the battery pin (with no battery connected) I have about 2v.
I tried to... -
by 2elwHey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
GW1N-UV9UG169C6/I5 FPGA - Its a...07-04-2025, 12:23 PM -
I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
by reformattLooking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,... - Loading...
