Samsung UE46f5000AK Stuck on Standby
  • Ukdigger
    • May 2020
    • 121
    • England
    When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
    PSU number bn44-00610A L46SF_dpn
    1 B13v 12.4
    3 B13v 12.4
    5 Vamp 12.4
    7 Vamp 12.4
    9 GND 0
    11 B5v 5.1
    13 B5v 5.1
    2 Pwm. Dm 0.3
    4 N.C 12.4
    6 BLU ON 4.7
    8 GND 0
    10 GND 0
    12 A5v On 5.1
    14 PS.ON 3.4​
  • Ukdigger
    • May 2020
    • 121
    • England
    Just noticed the pinouts are printed on the power board, pins 1 and 2 and 15 and 16 aren't used so I haven't got a short.
      • 12266
      • U.S.
      Could be you need to make sure the connections in the backlights are all good.
        • 12266
        • U.S.
        One example of a loose connection in this video: https://www.youtube.com/watch?v=eCG1rg7dVIQ
        • lotas
          • Jan 2016
          • 4741
          • Russia
          This power supply will not start without a load of 5v and 13v (there is protection), and accordingly there will be no backlight when the motherboard is turned off...
          • Ukdigger
            • May 2020
            • 121
            • England
            I think I've found the problem area, a tap on the top of the big heat sink with the handle of a screw driver turns the TV off and then on again. Can't see any bad solder joints.
            • Ukdigger
              • May 2020
              • 121
              • England
              It's only the 12v that goes on and off all other voltages stay on
              • Ukdigger
                • May 2020
                • 121
                • England
                It makes no difference if the backlights are connected or disconnected
                • R_J
                  • 9588
                  You need to resolder the connections on the transformers and any of the components mounted on the heatsinks ie: mofets diodes etc., usually the transformer connections are bad.
                  You may not see the poor solder joints but they are there, just resolder them adding more solder don't just re heat them
                  • Ukdigger
                    • May 2020
                    • 121
                    • England
                    I resoldered all the transformer connections and fets on the heatsink and now the TV stays on and it takes a hard tap with the handle of a screwdriver to make it turn off and on again. I will try doing the diodes next to see if that makes it any better. Didn't want to do too many things a once so I could pinpoint the the bad joint. Thanks for your help RJ. I will report back if I have any success.
                    • Ukdigger
                      • May 2020
                      • 121
                      • England
                      I went over the transformers again and now it doesn't turn off and on when tapped, so problem appears to be fixed. Thanks for all the help.
                        09-07-2024, 05:50 AM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • ChristianBr01
                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                        by ChristianBr01
                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                        04-23-2025, 01:48 AM
                      • Kaar3l
                        Samsung QLED QE65Q7FNAT only standby light
                        by Kaar3l
                        TV: Samsung QLED QE65Q7FNAT
                        PSU: BN4400940A
                        MB: BN94-12832K
                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                        09-24-2024, 01:35 PM
                        09-06-2024, 11:40 PM
