Originally posted by Diah
View Post
Philips 55POS9002/12 shorted mains
Originally posted by nomoresonys View Post
Interesting Diah, I would like to know how to do this also.Last edited by Diah; 08-07-2024, 12:20 PM.
Originally posted by Diah View Post
there are ready step down circuit less than $5 with regulator R to adjust the out put ... or do it yours self 3.3V regulator Transistor and 2200 uf cap 25V on the out put pin and GND ... same to 3.3V regulator which found on CH314 for example but we need one strong to handle currents
as lotas said. they will be high when PS_PN reach the PSU....
but because you had the issue at PSU.. then need to put the PSU alone on the table... and use stepdown circuit to have from 8.5V 3.3V and fed it to PS_ON... to be sure the PWM working and the vlaue will go high to 12 24V
But can we now confirm that the main board is the issue?
Originally posted by Henke View Post
It's flashing very rapidly. It's impossible to count. But first 3 ast and then pause and then around 40 very rapidly. Then it starts over.
i tried to film in slow motion and count. its around 40, but still hard to count.
What is there to explain, a Philips oled tv the tv goes into t-con protection if an error is "seen" that is panel related. This can already be due to dirty cables or cable connections, you can clean these with compressed air and IPA.
A thin line in the dispaly also could be a culprit.
To remove the t-con error you need special software, this is a small 20kB file that overrules the error.
Originally posted by William1967 View PostWhat is there to explain, a Philips oled tv the tv goes into t-con protection if an error is "seen" that is panel related. This can already be due to dirty cables or cable connections, you can clean these with compressed air and IPA.
Here is the picture over the mb. No voltage on the
caps that goes to usb etc.1 Photo
Originally posted by nomoresonys View PostSo what did you need to do, just put the an update on the usb stick or did you have to get the binary file to remove protection or what?
But is the TV still safe to use with that kind of solutions??
