Philips 55POS9002/12 shorted mains
  • nomoresonys
    • 12328
    • U.S.
    Originally posted by Diah
    as lotas said. they will be high when PS_PN reach the PSU....
    but because you had the issue at PSU.. then need to put the PSU alone on the table... and use stepdown circuit to have from 8.5V 3.3V and fed it to PS_ON... to be sure the PWM working and the vlaue will go high to 12 24V
    Interesting Diah, I would like to know how to do this also.
    • Diah
      • Feb 2013
      • 6555
      there are ready step down circuit less than $5 with regulator R to adjust the out put ... or do it yours self 3.3V regulator Transistor and 2200 uf cap 25V on the out put pin and GND ... same to 3.3V regulator which found on CH314 for example but we need one strong to handle currents
      • nomoresonys
        • 12328
        • U.S.
        Thank you sir.
        • Henke
          • Oct 2022
          • 41
          • Sweden
          Ok, now I connected only psu board and 3.3v from my bench supply to PS_ON. 8,6V rises to 12.55v as expected 👍 but the 24V_A pin (MB connector) also have 12.55V. I don't now what's happening there? Seems only to be separated by a few inductors from the 12V potential.
          But can we now confirm that the main board is the issue?
          • Henke
            • Oct 2022
            • 41
            • Sweden
            Originally posted by lotas
            Schematic
            Do you have the schematic for the main board as well?
            Or do I need to buy a new one as I don’t get the PS_ON signal to psu?
            • William1967
              • Nov 2017
              • 217
              • Netherlands
              #26
              Originally posted by Henke
              It's flashing very rapidly. It's impossible to count. But first 3 ast and then pause and then around 40 very rapidly. Then it starts over.
              i tried to film in slow motion and count. its around 40, but still hard to count.
              When the red led on the front is flashing very fast the TV is in t-con error, with a small piece of software that error can be deleted and the tv will start.
              • Henke
                • Oct 2022
                • 41
                • Sweden
                #27
                Ok, can you please explain little bit more in detail 👍
                • William1967
                  • Nov 2017
                  • 217
                  • Netherlands
                  #28
                  What is there to explain, a Philips oled tv the tv goes into t-con protection if an error is "seen" that is panel related. This can already be due to dirty cables or cable connections, you can clean these with compressed air and IPA.
                  A thin line in the dispaly also could be a culprit.
                  To remove the t-con error you need special software, this is a small 20kB file that overrules the error.
                  • nomoresonys
                    • 12328
                    • U.S.
                    #29
                    Now THIS is some interesting stuff.
                    • Henke
                      • Oct 2022
                      • 41
                      • Sweden
                      #30
                      About the software I meant
                      • Henke
                        • Oct 2022
                        • 41
                        • Sweden
                        #31
                        Here is the picture over the mb. No voltage on the
                        caps that goes to usb etc.
                        • William1967
                          • Nov 2017
                          • 217
                          • Netherlands
                          #32
                          I always use a USB with control led to see if there is activity.
                          • Henke
                            • Oct 2022
                            • 41
                            • Sweden
                            #33
                            Used a usb tester now. Activity when turning on the mains for a few seconds, after that nothing.
                            • Diah
                              • Feb 2013
                              • 6555
                              search the forum. i posted binary file to remove the protection sos for Philips OLED
                              • Henke
                                • Oct 2022
                                • 41
                                • Sweden
                                #35
                                it started up now. I downloaded a software with a usb stick. Thanks for all the help!
                                • Diah
                                  • Feb 2013
                                  • 6555
                                  you welcome
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    #37
                                    So what did you need to do, just put the an update on the usb stick or did you have to get the binary file to remove protection or what?
                                    • Henke
                                      • Oct 2022
                                      • 41
                                      • Sweden
                                      #38
                                      I put a small NVM.eed file on the stick and loaded it in usb port 1. As William wrote, the tv probably got into a T-con protection, and that file overruled it. so the fault is probably still there but have to try it little bit more to se if i notice something with the picture.
                                      But is the TV still safe to use with that kind of solutions??
                                      • Diah
                                        • Feb 2013
                                        • 6555
                                        yes tits safe , if there any at future issue with Cells.. there are Fuses on T-CON driver boards will monitor the EVDD currents.
                                        • nomoresonys
                                          • 12328
                                          • U.S.
                                          #40
                                          Thanks for clarification.
