lcd19-229 stand by light on and off
  • tonyuk
    replied
    Re: lcd19-229 stand by light on and off
    Originally posted by tom66
    ok thanks tom i will get there in the end but reading not my strong point
    hence why i fit kitchens and build cars lol
    replied
    Other places to buy
    http://www.ebay.co.uk/itm/ic-sop-8-A...-/400538572096
    http://www.aliexpress.com/item/AIC28...449252694.html
    BTW, dot always marks pin 1.
    replied
    From the pictures, it looks OK to me.
  • tonyuk
    replied
    It's actually AIC2857F. Is it physically burnt? Your results indicate it is not functioning, in the very least.
    One on eBay, they're about £5 each
    http://www.ebay.co.uk/itm/1PCS-Brand...item3cc84b952e
    but plan on about 2 weeks to get it from China.
    does look burnt when zoom in is that the only place i can get one lol
    replied
    See diagram here:
    http://www.analog.com.tw/p2_6_detail...idTableName=05
    Pin 2: input voltage, this is OK (12V from PSU)
    Pin 5: output feedback, should be 1.25V - not OK indicating the output voltage is not present
    Pin 7: on/off command, it is >2V indicating the main board processor says "I want power" but converter does not function. (Like a light switch which is on but with a blown light bulb.)
  • tonyuk
    replied
    hi tom that parts is burnt would that be all that the problerm is ? if so do you have link for that as cant find a match
    pin 2 = 12.83 pin 5 =000 pin 7= 5. my dot is where pin 1 is
    replied
    OK please check voltages on: pin 2, pin 5, and pin 7
    Pins are counted as such, starting from dot:
  • tonyuk
    replied
    Part # printed on device U7 please?
    the 8 leg ? number looks like ai A1C2857F GR8 09319 not sure if A1 OF IF ITS Ai
    replied
  • tonyuk
    replied
    Hmm, my error on the 1.25V. That is OK, it is just normal adjustable type. doh.
    Readings seem good, so there's little more to suggest.
    Can you see part U7 near one of those LDOs? What is the part # on it?
    yerp u7
    replied
  • tonyuk
    replied
    Can you try making the measurements as you turn the set on for the last three? You may have to turn it on and off a lot of times. A close picture of the power supply showing the label would help too.
    ok re-done list above with green light on
    replied
  • tonyuk
    replied
    ok so below is list
    1st
    =000
    =3.31
    =5.07
    2dr
    =000
    =3.32
    =4.98
    3dr
    =000
    =3.31
    =4.97
    this is the 1.25v
    =0.61
    =1.86
    =3.38
    this is me testing with light stuck on red stand by black lead to screw red to each pin left to right lol
    replied
    Haha, maybe for you, honestly I'd probably fit the kitchen upside down and have half the parts from the engine missing.
  • tonyuk
    replied
    20V, because that's the maximum range your meter can support. If you tried to read 3.3V on a 2V range, your meter would just show over-range ("OL" or single "1")
    ok thanks tom will check them and post
    fitting kitchens or building engines is so much easier
    replied
  • tonyuk
    replied
    Top are 3.3V, bottom is 1.25V.
    The voltages should be tested left to right, in the orientation in which the labelling on them reads the right way around i.e. you don't have to crane your neck
    ok and says you test on 20v setting yes ? even though i thought 2v would of been the way lol
    replied
  • tonyuk
    replied
    3 have 1117 b then under say 33 641
    1 has 1117 b then under say ade11u
    so im gues the top 3 r 3.3 volts ? and would test left to right
  • judamex
    MacBook Air 820-00165 turns on But no green and orange light, not charge
    by judamex
    MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
    03-06-2025, 03:55 PM
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:33 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    01-26-2025, 08:18 AM
  • lcdcaps1
    820-2610-A Sys onewire help, no green light. Please help from the gurus
    by lcdcaps1
    Hi
    I have an 820-2610-A motherboard that has no green light.
    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
    The sys onewire circuit on this model and others is more involved
    I was hoping if anyone knows about this and how it works, can reply and let me know
    I know this is an old model but I am sure there are people who still works on these or knows about them
    I get 1.1v on the C7771 capacitor and will replace...
    11-06-2023, 01:28 PM
  • blazzelia
    MBP A1286 820-2915 green light only, no start
    by blazzelia
    Hi guys,
    I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
    09-30-2024, 07:20 AM
