Samsung UN50TU7000 - Random Reboot
  • TVAddict
    • Jan 2022
    • 76
    • Caribbean
    Click image for larger version  Name:	20240727_144937506.jpg Views:	0 Size:	2.44 MB ID:	3317565Click image for larger version  Name:	20240727_145658334.jpg Views:	0 Size:	2.42 MB ID:	3317566 Click image for larger version  Name:	20240727_145714124.jpg Views:	0 Size:	2.22 MB ID:	3317567 Click image for larger version  Name:	20240727_145734870.jpg Views:	0 Size:	2.52 MB ID:	3317568
    Click image for larger version  Name:	20240727_144546893.jpg Views:	0 Size:	2.33 MB ID:	3317569
    Hi everyone, this model samsung tv works well until it randomly starts rebooting, it may do it within 5-10 mins after turning on or it may do it after a couple hours, sometimes it never does it, may work for days at a time.
    It has one the these AIO boards :
    I get 393dcv at the main cap see pic 2 and 12.9dcv at the stb test point as seen in pic 4 - this is with tv on and working.
    Any ideas or help is appreciated.
  • Diah
    • Feb 2013
    • 6397
    you have every things here in forum... yours issue at panel... only masking pins will let it work but with picture issue
    • TVAddict
      • Jan 2022
      • 76
      • Caribbean
      Even though the picture is perfect when the TV works, that's a bummer if it really is the panel, i tried searching for the model on here but it gives me 0.00 results?? Thanks for your suggestion.
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        Panel as he said, this board is also especially crap, all in one junk goes bad too.
          • 12206
          • U.S.
          Could be those things, I would start with simple stuff, unplug tv, hold power button on tv down for 30 seconds, replug and retry, no joy, do a simple firmware update, turn off all eco mode and power saving settings, disable hdmi cec. Any of that crap could be the problem.
            • 12206
            • U.S.
            Another experiment, point a fan at the back of the tv, see if it stops turning off, if it does then probably the bga chip overheating and causing problems.
            • TVAddict
              • Jan 2022
              • 76
              • Caribbean
              Thank you, i guess it's sometimes a bit of a guessing game with these AIO models.
                • 12206
                • U.S.
                Also try if you can, unplug any hdmi or component, rca cables and just use a simple tv antenna, a bad cable can cause problems.
                • TVAddict
                  • Jan 2022
                  • 76
                  • Caribbean
                  I feel i'm up to trying this, the cpu heatsink gets extremely hot in no time, you could fry an egg on that thing.
                  • TVAddict
                    • Jan 2022
                    • 76
                    • Caribbean
                    I have been running a blu-ray player on hdmi 1 maybe i can try another cable on a different hdmi input, tv antenna idea is good to try as well.
                    Thanks so much guys.
                      • 12206
                      • U.S.
                      Ok, my thought is that's the problem then, they shouldn't get fire-hot in a second.
                        • 12206
                        • U.S.
                        I think this happens a lot, specially since they went to lead free solder, they say it's good for environment, but not good for much else. The solder balls overheat, when they cool back down they can lose connection and cause issues. It's the constant cycles overheat, cool down, lose connection. Not a perfect solution but have seen diy reflows that have lasted a long time when coupled with a fan solution blowing right on the bga heatsink.
                        • TVAddict
                          • Jan 2022
                          • 76
                          • Caribbean
                          I think i will somehow put a small 12vdc fan over the cpu, will also try my reflow torch as well, maybe heat it up in hopes of it somehow making a better connection, and see how that goes.
                          Thanks again for all the tips and advice.
                            • 12206
                            • U.S.
                            Need to be careful with the reflow temps, too low and it won't help but too hot and it will cook the chip, youtube has a lot of diy reflows, some better than others no doubt. There has been a lot of yacking here about it too. Might be able to find a thread here in search but may be hard since the retooling they did, search is a LOT less effective.
                              • 12206
                              • U.S.
                              Check this thread, Howard did a lot of reflows, there's mucho good info in this thread: https://www.badcaps.net/forum/troubl...-no-backlights
                              • TVAddict
                                • Jan 2022
                                • 76
                                • Caribbean
                                Thanks for finding this link for me, yeah the search results have lost it's effectiveness, hard to find stuff.
                                Thank you so much nomoresonys, you're a true BC legend
                                  09-07-2024, 05:50 AM
                                • plytek
                                  Samsung QE50Q60TA rebooting
                                  by plytek
                                  Hi all.
                                  I'm trying to fix my Samsung QE50Q60TA TV.
                                  IT's rebooting every few seconds.
                                  I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                                  Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                                  Can anyone suggest what I can test and do to get it working again please?...
                                  02-08-2025, 06:02 AM
                                • unimatrix93
                                  SAMSUNG UE55TU7002KXXH rebooting
                                  by unimatrix93
                                  Hello everyone, I'm working on a Samsung TV that constantly rebooting.
                                  MB/PSU unit: BN9654185QE
                                  It loads up to the main menu then as soon as the backlight goes brighter it reboots.
                                  First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
                                  Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
                                  Also I have to note, that the MB/PSU combo gives out a very noticible...
                                  04-07-2025, 09:49 AM
                                  09-06-2024, 11:40 PM
