Vizio e420ar half screen dim
  • topfli8979
    • Oct 2012
    • 311
    Looking at picking up a vizio 42 tv, but I am wondering if the panel is shot. Guy who is selling the tv said, the tv was dropped, now left side works good but right side is dim. Picture is still clear, just dim. Panel issue or something else? These newer tvs dont have the ccfl bulbs correct?
    Re: Vizio e420ar half screen dim
    Well, its not an LED TV so it still uses CCFL/EEFL.
    Good chance some of the bulbs broken or the panel is bad. If it's the bulbs you're in for a lot of work. If it's the panel, you know it's not economical...
    Small chance the slave inverter is bad, but that's quite rare.
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Raulnn
      TD Systems K50DLG12US half black and half white screen
      by Raulnn
      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
      01-20-2024, 04:49 PM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
