Change name on tv after mainboard replacement
  • Ihandyrepair
    • Sep 2017
    • 44
    HI guys
    just quick question,
    I just fixed a dead Sony 55x800h, I replaced with a 65x800h board
    now works everything seems ok
    except that after factory reset, it will show 65x800h on the name,
    screen is 55 inch now
    I am guessing the size of the tv is programmed on the main board right?
    I could just change the name only
    or any way to flash the chip to make it to be a 55x800h instead?
    thanks
  • EazyBone
    • Jun 2023
    • 1363
    • United states
    Why change it? It works. Even before factory reset it should of shown the new board you put in as the "tv"
    IT should work and not effect anything though as far as I'm aware
    • R_J
      • Jun 2012
      • 9633
      You may be able to change it in the service menu
      • masterm
        JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
        by masterm
        TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
        Problem with TV:
        - Netflix stopped working so i tried to do factory reset from the TV menu.
        - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
        - After waiting for some time, the TV went into a boot loop.
        - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
        04-30-2024, 03:03 AM
      • Dogindelusion
        Sony XR-77A80K 5 Red Blinks Troubleshooting
        by Dogindelusion
        Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
        I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
        Observations:
        1) I noticed I was not getting...
        08-09-2023, 09:44 PM
      • sheffieldyorky
        ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
        by sheffieldyorky
        Hey there people
        While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
        This is what I tried, but not in any order.
        Google
        YouTube
        BIOS
        Command Prompt (administrator privileges)
        On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
        10-25-2025, 02:22 AM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
