Samsung ue55nu7021k Boot cycle
  • Yoda79
    • Dec 2021
    • 56
    • United Kingdom
    Hi, wondering if anyone can help with a tv which seems to turn on but turn off soon after and continue to do this cycle over and over again.
    It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the back and can see the backlights turning on. However when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
    Any thoughts, any help would be greatly appreciated.​
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4502
    • Italy - Milan
    usually there is a shorted glass panel, in some lucky situation only a bad cap or diode on the bevel boards..
    • EazyBone
      • Jun 2023
      • 1356
      • United states
      Yes, likely TV panel is bad, or as Davi said. Search for, fixing TV with tape, and watch the video. Try it see what happens.
      If you are more advanced check the buffer boards for shorts. If there are some report back here
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4502
        • Italy - Milan
        sorry,.border boards i mean
        • Yoda79
          • Dec 2021
          • 56
          • United Kingdom
          Thanks guys, just had a look at a video on fixing with tape. Where would you apply the tape, to the part of the ribbon which connects with the main board or the part which joins what I believe is called the TCON, although I don't seem to have an obvious one?
          I have 2 ribbons, and disconnected each in turn and with both the tv doesn't constantly reboot and stays on, as I can see the back lights staying on. With both ribbons, when I disconnect one, the sound comes but not when both ribbons are connected. I had assumed that by connecting a good ribbon, some the picture may come on but not the case, what would that suggest?
          I'm not advanced but can I ask how you check the buffer boards for shorts?
          Thanking you all again for your help.
          • EazyBone
            • Jun 2023
            • 1356
            • United states
            There is no stand alone TCON here. You can tape any side you want. Main board or buffer board side. This is basically just a diagnosis test that may help see if it's actually the panel. It's not 100 percent but works well. Pick a side, cover like 8-16 pins, try different ones. And generally try the edges with the tape, it's usually not in the middle pins of the ribbon.
            Also the buffer boards are under the speakers and metal cover. For this you need multi meter.
            Try the tape, it's rare that buffer boards have short but not unusual
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4502
              • Italy - Milan
              On border boards there are some bigger caps,test them across for short
              • Yoda79
                • Dec 2021
                • 56
                • United Kingdom
                Is it strange that I get the same result when I take each ribbon out, in that in either case the power is steady (doesn't reboot) and I hear sound? I had assumed one would deliver steady power and the other would cause it to just reboot highlighting that the ribbon with the fault? Which then allows me to start to test that particular ribbon?
                • Yoda79
                  • Dec 2021
                  • 56
                  • United Kingdom
                  Sorry can I ask what you mean by bigger caps? Also, I have a multimeter but how would I test for shorts? Not testing the buffer boards yet as will check the ribbon and tape off as suggested here, but curious on this now.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4502
                    • Italy - Milan
                    the border board consists of different sizes of caps (capacitors), test in ohm for almost zero across the big ones
                    • Yoda79
                      • Dec 2021
                      • 56
                      • United Kingdom
                      Ok great. So to get to the border board, do I just remove the speaker and then remove the cover plate?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4502
                        • Italy - Milan
                        of.course
                        • EazyBone
                          • Jun 2023
                          • 1356
                          • United states
                          I believe there is a spot to jumper/solder on the board you have to do before you can remove just one side of cable and get half a picture. So no not unusual for this TV. Tape in the correct spot should give you a startup. Works for me bout 90 percent of time if I hit the right "spot"
                            09-07-2024, 05:50 AM
                          • NolesFan
                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                            by NolesFan
                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                            10-24-2024, 06:36 PM
                          • meraklinetx
                            Asus Z97-a power cycle, no boot no cpu voltage
                            by meraklinetx
                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                            05-10-2023, 06:08 AM
                          • Egidio85
                            Samsung UE55F8000SZ Turns on and off immediately
                            by Egidio85
                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                            This defect happens continuously, hearing the classic click of the relay every time.
                            Power supply board BN44-00636B
                            disconnecting the mains and lamps from the power board always causes the same problem.
                            Is it normal that without anything connected this power supply turns on and off cyclically?
                            any suggestions on what to check?
                            thanks in advance
                            03-11-2025, 12:45 PM
                            09-06-2024, 11:40 PM
