Inverted Colouras on Samsung LE37M87BD
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys bought this telly form someone (as faulty) , plugged it in and all the colours are inverted, there was a buzzing coming from the tv and after i turned down contrast etc the buzzing went away. any ideas ? also went into service menu and changed DDR to Samsung.
    Re: Inverted Colouras on Samsung LE37M87BD
    Pic of fault?
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      hi Tom, attached picture, also there is a little ghosting on the picture too.
        Could be GAMMA or LVDS/FORMAT fault. A natural image (a face is best due to the smooth gradients) can help narrow down the exact fault.
        First check LVDS cable seated properly both ends, no corrosion on any pins, no bent pins.
        If that passes enter service menu and check LVDS format option: there may be a few, JEIDA is one of them. Try each and see if picture gets better. Also check panel setitng is correct - AMLCD 37" for example is SAMSUNG 37" panel. Note down all settings before changing them.
        Should those fail then a picture of the T-con is necessary to check gamma voltages.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          hi Tom, couldn't find LVDS option anywhere on the service menu ?
            What options do you have?
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              hope this helps Tom.
                Ok, looks like no option for LVDS format, so time to focus on t-con.... good clear photo required.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  Tom cant get a clear enough picture, broke my camera and my phone camera is a pile of sh*t... the T-Con board thats on it is T370HW02 V0. looked it up on ebay and they have a repair service for this specific board, costs £75 though and dont realy wanna spend that kinda cash when it might not even be the fault, the pins on the LVDS cable took fine and the board itself looks in excellent condition.
                    Same board as this one:
                    https://www.badcaps.net/forum/showth...ng+LN37A550P3F
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      no Budm its exact same one attached (taken from Google images)
                        I see, my version is 402, it does use the same AS15 Gamma Vref IC.
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          do you think that could be the problem ? how easy is it to fix, i have some soldering skills but dont think i could do something that complicated.....
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            is that whats in place U603 ?
                              U21 in your picture, and I believe the test points that Tom wants you to test is the row on the top right close to that IC. Tom can give you more details about testing those voltages.
                                You should test the points marked VGAMA1 thru VGAMA22. Meter on 20V DC, board installed in TV and showing pic, red pin on test point and black on chassis ground. Report your readings.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  sorry for late reply guys, Tom did what you said got following readings..hope this helps..
                                  VGAMA1 0.02
                                  VGAMA2 0.18
                                  VGAMA3 0.29
                                  VGAMA4 1.84
                                  VGAMA5 3.39
                                  VGAMA6 4.92
                                  VGAMA7 9.85
                                  VGAMA8 12.35
                                  VGAMA9 12.81-12.87 (was jumping up and down)
                                  VGAMA10 12.92
                                  VGAMA11 7.62
                                  VGAMA12 15.02
                                  VGAMA13 15.41
                                  VGAMA14 15.38
                                  VGAMA15 15.15
                                  VGAMA16 14.84
                                  VGAMA17 14.25
                                  VGAMA18 14.14
                                  VGAMA19 14.03
                                  VGAMA20 14.01
                                  VGAMA21 14.01
                                  VGAMA22 14.00
                                    It is bad.
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      is it repairable Budm or will i just have to replace it ?
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        would this one do the same job, same number but from a different tv of a different size?
                                        http://www.ebay.co.uk/itm/VIZIO-GV42...item27df6b3c9d
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
