My 4 or 5 year old LG 50PQ30 is displaying a window asking if I'd like to enjoy my new device. If I select "yes", it switches to AV2, and there is nothing plugged in that input. At times it starts flashing this message every couple of minutes, and if you turn it off, it may pop right back up. I've reset the tv, that hasn't helped, and LG says they have not heard of this issue. Anyone have any ideas, or is it time to scrap it?
Weird problem with LG 50 PQ30
Re: Weird problem with LG 50 PQ30
Have you tried cleaning the socket - check for bent pins. If the set is 4-5 years old
and not been opened may be worth trying spring clean in case dust is conducting.
Try plugging something into the AV2 (after cleaning) see if that stops it.Please upload pictures using attachment function when ask for help on the repair
by chaos-theoryHello!
I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a... -
by c.danielLenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
sn LR09493E
MB DAOLV6MB6F0 REV. F
The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then... -
Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by brockaulyHi guys,
If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
Then if I unplug the charger and plug it back, it won't charge anymore.
In the first case, main voltage is regulated at ~12.5V and charges the battery.
After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned... - Loading...
