Philips TV 47pfl5603d/27 - Backlight Issues on Certain Sources
  • jbradlee
    • Feb 2014
    Good morning, all! I have a headscratcher here and my Google-fu is failing to find any good pointers.
    I have a Philips 47pfl5603d/27 which we've had for several years now. It's nothing special but it worked well especially with gaming via HDMI. Lately though it's been trying to drive us crazy - the backlight will randomly shut off when using a non-HDMI source!
    Our cable (standard-def) is plugged in via coax and our DVD player is in through component. I have a PS3 and PS4, both on HDMI. When using a NON-HDMI source, the backlight will often shut off randomly. Cycling power will sometimes fix it but not always. While on HDMI, it very rarely loses backlight AND if it does, cycling power restores it.
    So, my initial theory of bad inverters appears to be shot. I don't think this set has an auto-backlight off feature, and I don't know why it would be triggered while in active use anyways. My amateur DSP mind is thinking it may be a signal strength issue causing the set to think it's not in use?
    At this point, I'm prepared to crack it open and put a multimeter to it, but if there's something that can be done prior to that, since it may be going on a one-way trip, I'd like to make a go of tests and fixes that don't involve disassembly.
    I just remembered I have a PS2 I can try using both composite and component hookups - maybe that will be telling. I can also move the DVD player inputs from the back panel to the side A/V jacks.
    Does anyone here have any thoughts on what else I should be testing for? And if I need to open it, what area I should focus on inside?
    Thank you all!
  • chestercc
    Philips TV Backlight Repair
    by chestercc
    So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
    My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
    The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
    11-18-2022, 01:15 PM
  • ohren
    Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
    by ohren
    I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
    The setup is basically:
    Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
    Transistor is switching the 3.5 V supply on the power board....
    12-05-2024, 11:10 AM
  • Patrick501
    Philips 55PUS6704 no picture, backlight ok
    by Patrick501
    I'd like to repair a Philips 55PUS6704.
    It turns on and you can see the backlight, hear the sound but no picture.
    When I disconnect one of the T-con cables, half of the screen turns white.
    right cable disconnected= right side white
    left cable disconnected= left side white
    When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
    There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
    Also you can notice one single...
    11-12-2025, 08:46 AM
  • ovrax
    Philips 55PUS6804/12 turn on & off (probably backlight issue)
    by ovrax
    First of all, please excuse me as I'm quite new to this field.
    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
    The Ambilight works perfectly and stays on.
    No sounds.
    Thanks in advance.
    08-25-2024, 04:33 AM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
