help finding kubnkm133la inverter
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    i can t find the master and slave inverter
    6632l-392b. & 6632l-0393b
    any help only place in in uk and shipping is. to much
  • tw2005
    • Oct 2011
    • 6458
    Re: help finding kubnkm133la inverter
    here's one (master) all revisions a,b,c,d are compatible from what I read on SJ and here .
    http://www.ebay.com/itm/TX-47F430S-I...item5661df356c
    • tw2005
      • Oct 2011
      • 6458
      here's a repair kit. looks like you need one for each.
      http://www.ebay.com/itm/6632L-0392A-...item25700d8487
      • tw2005
        • Oct 2011
        • 6458
        here's slave with a ? on whether it works, untested.
        http://www.ebay.com/itm/LG-6632L-039...item1c3b0abdf2
        • tocold4u2
          • Dec 2012
          • 284
          • usa
          yea saw those on ebay..i need the same boards that i posted
          the others wont work.
          thanks for the help.
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            has to be. 6632l-0392b & 6632l-0393b. kubnkm133la
            boards cant be. a,c,d. from what i understand the other boards
            wont work
            • tocold4u2
              • Dec 2012
              • 284
              • usa
              Well i located a set of boards and they were at a great
              price. i should have them twards the end of the week.
              Will keep ya posted on a update !!
              • cheeky2
                Help with bypassing the OZ9928SN inverter ic from I470H1-20A MASTER LG 47LG5000
                by cheeky2
                Merry Christmas
                Does anyone know how to bypass the protection ic OZ9928SN on a LG 47LG5000 inverter using a I470H1-20A MASTER pcb?
                Pictures attached
                Thanks in advance...
                12-26-2024, 05:25 AM
              • eccerr0r
                inverter H tree driver imbalance in an AC inverter
                by eccerr0r
                My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                Today, 12:34 PM
              • x_orange90_x
                Vizio E55-E1 bad backlights or bad inverter?
                by x_orange90_x
                I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                I don't know how exactly to test the inverter itself. Is it...
                01-29-2025, 09:24 PM
              • JFarm
                Sharp Aquos LC-46E77UN inverter testing
                by JFarm
                I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
                The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
                03-21-2021, 11:10 AM
              • crushkittykitty
                CMO I420B1-16A (27-D012836) backlight inverter master and slave
                by crushkittykitty
                origanlly the backlight would come on and go off in my great ability to repair I hooked up a test light per instructed master side top 6 would only partially light slave side lit test light fine, pulled tv down to bulbs, same bulbs inside only halve lit. seems master inverter at fault tested all transformers all seem fine, pulled top transformer from master double checking test points reinstalled cleaned up all connections noted on back of master center of board dark spot, checked around that area everything on top of board seems fine, resoldered the 0 resistors plugged everything back in turned...
                07-16-2016, 02:32 PM
