Sony KDL 55W-955B Sony EMMC dump search :)
  • Morosan Dimitrie
    • Jun 2024
    • 7
    • Romania
    Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
    KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B, KDL-50W828B, KDL-55W828B, KDL-55W829B, KDL-50W829B, KDL-50W817B, KDL-55W817B, KDL-50W705B, KDL-50W706B, KDL-40W705C, KDL-32W705C, KDL-48W705C, KD-85X9505B, KD-65X9505B, KD-79X9005B, KD-65X9005B, KD-55X9005B, KD-70X8505B, KD-65X8505B, KD-55X8505B, KD-49X8505B
    Please maybe someone has a dump from those model so I can try. If it helps to motherboard code is 1-889-347-11.
    Thank you in advance!​
  • Diah
    • Feb 2013
    • 6483
    why you suspect the emmc... sony W series are known of BGA issue at Vision Soc
    • Morosan Dimitrie
      • Jun 2024
      • 7
      • Romania
      Because I check the power supply and is sending power, I tried to reflow the emmc without succes same thing. I check for short circuit whole motherboard and everything ok and when I check the emmc information from it is corrupted.
      • Morosan Dimitrie
        • Jun 2024
        • 7
        • Romania
        I hope maybe I can find someone to help me with a copy from a working emmc to try it 😁
        • lotas
          • Jan 2016
          • 4796
          • Russia
          Someone else's firmware does not work on this chassis, you will get error "3". These boards have defective memory chips (DDR).
          • lotas
            • Jan 2016
            • 4796
            • Russia
            If you want, try it.
            Dump was read by the UFPI programmer, rename the files to suit your programmer (RT809H).​
            https://disk.yandex.ru/d/BD76IPmmBNiWLw
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4507
              • Italy - Milan
              emmc reballing is required i guess.. if also corrupted files also emmc rewrite..
              KDL-55W955B
              • Morosan Dimitrie
                • Jun 2024
                • 7
                • Romania
                Hy guys. I change the EMMC with a new one and put the dump from lotas on the new EMMC and now I have 3 red led blinks. Before was no light present no blinks, from what I search on internet I should update the firmaware? Thanks for all the help!
                • lotas
                  • Jan 2016
                  • 4796
                  • Russia
                  I wrote above that someone else’s dump will not help you, you will get error 3 (on this chassis), and that’s how it happened. In this chassis, dump is encrypted and linked to the processor ID...
                  • Morosan Dimitrie
                    • Jun 2024
                    • 7
                    • Romania
                    And there is no chance of fixing some how this error ?
                    • lotas
                      • Jan 2016
                      • 4796
                      • Russia
                      Look for a donor (motherboard).
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4507
                        • Italy - Milan
                        there is a little chance, as i have said, that original emmc is ok, but you like others does not trust me..
                        • CapLeaker
                          Leaking Member
                          • 8340
                          You should have first figured out if there is data flowing between D0 and the other data lines between the EMMC and the main processor. It will tell you if you got a bad EMMC or bad firmware.
                          • Morosan Dimitrie
                            • Jun 2024
                            • 7
                            • Romania
                            How can I check this ? With an osciloscope to see if exist a signal ?
                            • CapLeaker
                              Leaking Member
                              • 8340
                              Yes.
                              • Morosan Dimitrie
                                • Jun 2024
                                • 7
                                • Romania
                                Hello guys I m back again, from what I found on Internet I see that for this model sony modify the EMMC to work on the enhanced mode which now I understand why It was showing me half of the capacity. I ordered a stencil to fix back the bga ball of the old EMMC and I will come back with an update.
