bush 42 3d tv well samsung :)
    Re: bush 42 3d tv well samsung
    Check each of the transistors on the heatsink - though the very fact the voltages drop out when it is connected is indicative of a fault and the board should be replaced.
    Note without the X-main you could get a little flicker from the screen when turned on with only Y-main - try in a dark room - the control board will quickly shut down though so it will only be quick.
    • adamp91gvm
      • Jan 2014
      • 699
      I tried I get power of 0.41v to the 2nd 4th and 5th and nothing to the rest top being the one by xs
      • adamp91gvm
        • Jan 2014
        • 699
        And I get a flicker from the y main just bing in a flash of white with black lines
        • adamp91gvm
          • Jan 2014
          • 699
          Does that mean my y main is ok
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Think so!
            So,--You need to repair or replace the X-SUS board.....
            Whats the going rate for 'em?
            TELEFIX
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              Just checked--If you're really stuck, Ive got a known good and tested X-SUS for a 42C450, I was keeping as a spare for mine....
              TELEFIX
              • adamp91gvm
                • Jan 2014
                • 699
                #27
                How much mate I have been looking at a few
                  You don't want to be checking for "power" (I presume you mean voltage; voltage is not the same as power though) you want to check each transistor or diode for shorts, using your multimeter on the ohms range.
                  • adamp91gvm
                    • Jan 2014
                    • 699
                    #29
                    Is this a compasitor because I'm getting 15v from one side and nothing from the other but it goes to every circuit on the board and there is no volts after it could this go bad
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      wrong thread sorry
                      • adamp91gvm
                        • Jan 2014
                        • 699
                        #31
                        The problem I'm having is I'm not getting power to the rest of the board but 15v goes up to there
                          That is a capacitor. Decoupling the 15V supply.
                          Now, if the 15V is present but Vs/Va are missing, it suggest a short on Vs, preventing it from reaching ~205V.
                          Have you checked the heatsinked transistors for shorts?
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            #33
                            Where do I need to test on them ?
                              Just check across all three pins, both ways, on diode mode.
                              • adamp91gvm
                                • Jan 2014
                                • 699
                                #35
                                What black on one red on the other and mix it up it get the combinations
                                • adamp91gvm
                                  • Jan 2014
                                  • 699
                                  #36
                                  The one with the pin sticking out is not going to 0 it's going to 0.98
                                    All combinations.
                                    Mentally number pins 1-2-3 in any order but be consistent over each device, for two pin devices just use 1-2.
                                    Then check red 1 black 2, red 1 black 3, red 2 black 1, etc...
                                    • adamp91gvm
                                      • Jan 2014
                                      • 699
                                      #38
                                      Ok right top one goes to 0 all combinations
                                      Second down stayed on 1
                                      3rd stays near enough one 1 all combinations
                                      4th 5.02 on pins 1 to 3 and stays on 1 on any other combination
                                      5th 5.02 all combos
                                      6th goes to 0
                                        So there's your fault, shorted sustain transistors. I'd take Alistair up on his offer of a board.
                                        • adamp91gvm
                                          • Jan 2014
                                          • 699
                                          #40
                                          I found one for 19 delivered I asked Alistair but he never got back to me not ordered it yet like
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 06:20 PM
