I have clicking sound when turning ON tv, red light goes off and on. When I disconnect white cable from the left side of power board the tv stays ON but of course no picture. Anyone knows where can be the problem?
Lg 42pj350
Re: Lg 42pj350
I have replaced on power board:
2x 5W22R Vertical Ceramic Resistor
1x 3BR1565JF
but that not helps this time, but works fine with my LG 50pk350.
I have no backlight and can hear buzz sound when turning on tv for a second.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Lg 42pj350
Meanwhile I've measured voltage on power board on the connector to the Y-sus board with disconnected Y-sus board:
VS - 205
VA - 60
M5 - 5
and on the connector bottom right:
17V - 17
5V - 5
STB - 5
AC DET - 4.1
AUTO GND - 3.2
what else should I troubleshoot?
the buzz sound is going from center of the y-sus board.Last edited by sekino; 02-15-2014, 01:15 PM.Comment
Re: Lg 42pj350
You have a fault on one of the 'SUS' boards.
Re-connect the PSU plug, remove the plug from X-SUS and re-try.
--If PSU stays on--fault is on the X-SUS. If just the same--fault is on Y-SUS.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Re: Lg 42pj350
hopefully i get your point right, please look at my picture attached:
1. if I disconnect plug from power board to Y-sus board (yellow rectangle) the tv stays ON
2. if plug from Y-sus board is connected but i remove plug from X-sus board (red rectangle) the tv is turning off and on.
I assume now that Y-sus board is faulty, what can I check on this board?Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Lg 42pj350
Ah--But.....
Isnt the PSU plug going To the Y-SUS and the X-SUS thick wiring going TO the Y-SUS?
So--You would need to test as I described.
Power first goes to Y-SUS from there it goes to X-SUS.......TELEFIX
Re: Lg 42pj350
I don't get it. Please look at my picture.
1. First I disconnected plug 1 > TV stays ON
2. Then I reconnected plug 1 (that means all plugs connected) > tv turns off and on.
3. With reconnected plug 1 (that means all plugs connected) and disconnected plug 2 > tv turns off and on.
If I should test something else please highlight it on my picture.
Thank you very much.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Lg 42pj350
OK so.....
Short or fault on Y-SUS board, probably on the Vs supply.....
Set Unplugged from mains, and PSU plug (1) unplugged, what resistance to chassis do you get on the pins marked Vs of the Y-SUS board plug?TELEFIX
Re: Lg 42pj350
OK--so no obvious shorts then.....
How about if you disconnect the buffer-board from the Y-SUS and re-try with all plugs back in?TELEFIX
Re: Lg 42pj350
Not quite.....
The long green panel on the left is the Buffer-board. As I recall--there's a row of screws that connect the buffer to the Y-SUS where they overlap.
You'll need to remove all those screws, and separate the boards so there's a small gap between the boards as well as that small white flat lead--Then re-try.TELEFIX
Re: Lg 42pj350
Bad Y-sustain. Common fault with these models. A repair kit might be available but you also might have to swap whole board...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: Lg 42pj350
As there's no obvious shorts, I would start looking around the DC-DC converter stage at the bottom of the board.
(No supplies from this, I would expect the set to shut down)
Check the IGBT's/MOSFETS and diodes on the heatsink anyway for any leaks/shorts....TELEFIX
Re: Lg 42pj350
I've checked resistance on all black caps and green things (sorry I'm not technician
) can you please mark on my picture what everything should I check? I'm desperate. I don't know which one is DC-DC converter etc... Thank you very much
Re: Lg 42pj350
TBH--I think in your case, the replacement of the complete board would be the best solution.
Some knowledge of the different parts, how to test them and correctly interpret the results is needed, as well as the skill and tools to safely remove and re-fit the parts without damage.
The DC-DC Converter--Isnt a single item, but on that board is probably 20 or 30 parts make it up--Any one of those parts could be faulty--Or not!....
--They are around that square yellow thing at the bottom (Transformer)TELEFIX
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
- Loading...
