Whats the highest Use time you've seen on a Plasma set?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    The highest Ive seen still giving a great picture was a Samsung with 25,000 odd hours on.
    They say the panels are good for 60-100 thousand, time to half-brightness...
    Whats the highest times have you seen? At these high times--what picture issues could have been due to just old age did you see?
    TELEFIX
    Re: Whats the highest Use time you've seen on a Plasma set?
    I think Freakaftr8 had a Pioneer with 70,000 hours on it but it needed high VSUS to work (240V+)
    Me personally I have had one with 16,500 hours, Panasonic 42" PZ8B, not a lick of burn in or maldischarge, had 10 blinks (PSU fault.) It looks just as good as my 46" PZ80 with just 3,500 hours on it.
    • freakaftr8
      • Oct 2012
      • 3743
      Indeed. The pioneer I had had crazy hours on it. 70 thousand and some change. A quick vsus adjustment brought it back from the grave. The screen literally didn't fire and if left o. For 30 mins you would see the outside light up around the frame only.
      • tw2005
        • Oct 2011
        • 6458
        I top out at about 10 000hrs. There's roughly 8760hrs in a year so 70000hrs plus equates to 8 continuous years of use minimum!
        Must have been a TV junkie or commercial display?
        • sgeorge
          • 16
          i have a 43" pioneer with about 12,500 hours on it. has an excellent picture.
          also have a 64" pioneer rear projection 2003 year. still has a fantastic picture on it also. steve
          • Jester11
            • Feb 2014
            I had no idea the panels lasted this long. Very good information to know!
            • ArMaaN376
              Samsung PS51E550 Plasma TV
              by ArMaaN376
              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
              Opened TV cover & observed foll
              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
              How to confirm Y -Buffer board...
              06-19-2024, 04:05 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • alltvrepairs
              Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
              by alltvrepairs
              I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
              I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
              Any one met this problem in the past?...
              10-08-2025, 07:34 AM
            • chazh
              LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
              by chazh
              This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
              I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
              The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
              09-01-2025, 08:56 PM
