Panasonic TH-42PZ70B 10 Blinks
Re: Panasonic TH-42PZ70B 10 Blinks
Hmm.. not sure I guess others will know more than I do. I can say 1uF worked in mine. But I'd guess no harm in replacing with the value you measured.
Also of interest, there was a Panasonic tech on here who said with the PZ80 (different PSU but similar MC201/301 problem) that the official Panasonic fix is to just to remove the cap. See this thread here:
https://www.badcaps.net/forum/showthread.php?t=32334Comment
so they must be different enough to make a difference.... bummer
Think I need some freeze spray to start checking IC's n stuff (note I also removed the caps on my 50' and it changed the flash code??)Comment
You can get cans of compressed air from Poundland in the UK, £1 for 200 ml, it also works as freeze spray by inverting the can.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
thanks I'll get some in the morning and have a go over the weekend.
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
Hello all,
As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere... - Loading...
