Panasonic TH-42PZ80B - Completely dead again
    I had this nice 42 inch 1080p Panasonic plasma working in my bedroom for 5 months (it was the one with the cold joint on the power board.)
    I decided 42 inch plasma is way too big for me so I got a 32 inch 1080p Sharp Aquos cheap for fixing up and sold this one, but a day later it came back with the original fault (talk about bad luck!) So I gave the guy his money back...
    I've since traced it down to the AC detect board, which tells the PSU if the AC is present. I've found that when I freeze spray it, the TV will power up and work fine. Once it warms up, it only powers up intermittently.
    I believe it's one of the ceramic caps on the AC detect board, but I can't be sure because the only schematic I have of it is the one I've reverse engineered (see below.)
    https://www.badcaps.net/forum/attach...8&d=1367795705
    I drew the PNP Q3 backwards in that by mistake. The emitter faces BIAS-9V and the collector is the output. C3 is the suspect. It's the biggest cap on the board by far, and it appears to be the only one where if it failed leaky, it would cause Q3 to stay off. It would have to fail very leaky (probably shorted.) But I cannot know it's value unless anyone else can measure it.
    If I can't fix this part, I may have to think of an alternative AC detect circuit design... ideas coming soon.
  • Blanqui
    • Oct 2013
    • 12
    • España
    Re: Panasonic TH-42PZ80B - Completely dead again
    Hi tom.
    This looks like you have to do a mod to this one.
    There is a daughterboard on the powerboard. There you will find an IC which is a TEA1611T. You have to remove the 1uF cap that's between pins 11 and 13 from that IC.
    Hope that helps!
    • tw2005
      • Oct 2011
      • 6458
      Which board is the AC detect board Tom?
        Originally posted by Blanqui
        Hi tom.
        Hope that helps!
        Unfortunately that's not the issue with this model, that would be too easy! Though the cause seems to be the same (leaky ceramic cap.) My set does NOT have a 10 blink or 2 blink code. It is completely dead. No power LED, no relay clicks, until you give a freeze blast to the AC DETECT board (which is an MC MODULE but it's not the TEA1611T boards.) Then it fires up and works perfectly until it warms up and the AC detect signal goes awry, causing it to intermittently shut down and restart as if the power cord were loose.
          Will check when I open it up but it's one of the few that crosses the PRI-SEC boundary. Has two optos on it.
          • Blanqui
            • Oct 2013
            • 12
            • España
            Sorry, tom66. But don't you have MC201 on this TV set?
            It's writren on my notes...
            How weird!
              How weird!
              Yes, I do. But amazingly, both of my PZ8 series plasma repairs have not involved either MC201s. I got one with a loose LVDS which is still looking good in my lounge and playing fine after 6 months. And this one with AC detect issue. I have a friend who's fixed two PZ8 series with MC201 issues.
              • tw2005
                • Oct 2011
                • 6458
                Ok, so we're talking one of those module boards that they give no info on in the standard schematic for the PSU. I've got the 46" PSU I'm yet to do for the 2/10 blinks on, probably similar PSU but I have no capacitance meter. Would have to pullit out and track down a meter at work to measure it next week if you're really stuck.
                  I appreciate it. I've got an idea though involving using an 230V AC coil relay. I'm going to take 230VAC from the input and connect it to the relay, lift the opto and wire the relay's NO switch terminals to it.
                  I need to find a good AC relay with a sub 16ms release time. (~1 cycle AC.)
                  I'd like to do a proper repair though just replacing that capacitor, so I'll have to see if I can narrow down the fault any further.
                  • Blanqui
                    • Oct 2013
                    • 12
                    • España
                    The capacitor doesn't have to be replaced, it has to be removed.
                    This is the repair suggested by Panasonic, I'm an ASC. I mean that this is the proper repair, LOL.
                    Anyway, maybe I got a little lost in translation. From your last post I haven't understood if you were saying you had or not that board.
                    Sorry for my English!!!!! :p
                    • tw2005
                      • Oct 2011
                      • 6458
                      This board?
                      how critical would the value of the cap be do you think? Would it be worthwhile just finding a ceramic physically the same size from a scrap board?
                      Worst thing that could happen is it still does not work, surely?
                        Yeah, I know about the MC201/MC301 repair but that's not the case with this TV. Since you're an ASC, could you look into whether my particular issue with the AC detect is also documented? (symptom: no power LED, TV acts DEAD, fuse is NOT blown) Maybe it gives the value of the cap.
                        Your English is fine, better than many natives of this country. I cannot speak Spanish at all so no need to apologise!
                          This board?
                          Yes, that one. MC501...
                          It's much worse unfortunately.
                          If the AC powers off and the TV keeps the VDA high while the 5V collapses, the panel goes BANG. And you get a dead driver chip and a dead panel. (Secondary breakdown due to overstress of IC, reverse biasing the diode between 75V and 5V in the IC substrate.) There is something like 3000uF of Vda capacitance (@75V) and only 1500uF of 5V capacitance so it's possible that the Vda will hold out while the 5V collapses. (I believe there's a discharge circuit which detects if AC turns off and dumps the Vda energy quick.)
                          It is documented in many PDP datasheets, I did not realise it until recently, but it's very important for the power voltages to be sequenced exactly, they specify it on the voltage page. If not, the panel can be damaged. I remember doing AC detect bridge on LG 42" plasma and others have done it on 50" plasma. Those seem OK, I tried that TV hundreds of times with no issue, but they did not engineer them as overkill-ish as Panasonic with only about 500uF of capacitance on Vda and 7500uF+ on 5V. So I could get away with it on the LGs, but I do not know if I can do so on a Panny and I don't fancy finding out...
                          • tw2005
                            • Oct 2011
                            • 6458
                            Don't mean to hijack but,
                            Are you talking about the MC201/301 modules or the module Tom's working on?
                            I'd be interested on any info on the MC201/301 modules if all it needs is a cap removed, save me taking the module out.
                            are there any service bulletins you can share?
                            • tw2005
                              • Oct 2011
                              • 6458
                              Ok, that's beyond me but good to see someone thought about it. LOL
                                The other issue I haven't considered is it might do a 2, 4 or 10 blink code when AC power is removed while running, not sure if AC relay will cause this or not. All a matter of getting timing right.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Well that module MC501 MDPTZA101 is found on 42, 46 & 50" models, I guess you don't have another PZ series laying around?
                                    I do, 46". I'm leaving taking apart that as a last resort because it's used every day at the moment. The 42" can wait for now.
                                    Though I may be getting a 50" 2011 Panny Pro 3D 1080p plasma monitor soon to play with, if the auction comes thru... that ought to be fun... supposed to be the equivalent of the TH-P50UT30 but with only HDMI and DVI... faulty though... If I put that on the wall I'll tear the 46" open.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      That module looks like it's available $40-50 in the US, not as much fun or cheap as a single component repair.
                                      I thought you had a 46" too, I thought my memory was going there for a moment.
                                      Yes i understand how painful it is pulling the back off and getting the PSU out , probably why I have not gone back into mine again. Interesting that the MC201/301 only needs that cap removed.
                                      Could have saved $25 on 2 TEA1611 ic and the tiny caps. I might just give it a go removing that cap first because I did get it going again just reflowing it but it has failed good and proper now.
                                      is'nt the UT30 series the generation that quite a few are having the SC boards go like the poor chap in the states that had his repaired under wty only to have the same fault 6 months later and be left high and dry out of wty?
                                      • Blanqui
                                        • Oct 2013
                                        • 12
                                        • España
                                        Hello, tw2005.
                                        I thought tom66 was suffering from the MC201 module but it seems it's not the problem.
                                        In any case, the problem this module suffers from is the cap between legs 11 and 13 of IC TEA1611T.
                                        Referring to your request, tom66, there is no mention to what you say. The closest thing is to replace MIP3A and the fuse on the standby power supply. But I guess your fuse is right and don't need to replace MIP3A.
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • wangbreeze
                                          T480s random shutoff and then completely dead
                                          by wangbreeze
                                          Hello Gurus,
                                          I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                          I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                          Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                          charger gave - 20V - ok
                                          U101B
                                          02-03-2024, 04:57 PM
                                        • pavski
                                          Completely dead MSI z490 tomahawk
                                          by pavski
                                          Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                          I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                          t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                          Can you please let me know if this is indeed incorrect and what else should I look at next?
                                          Thanks!
                                          06-02-2024, 02:42 PM
                                        • Andreasbest
                                          Lenovo Thinkpad T14s completely dead.
                                          by Andreasbest
                                          Hello.
                                          I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                                          I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                                          Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                                          Thank you in advance!
                                          Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                                          03-19-2024, 03:18 AM
                                        • armini
                                          18VDC PSU completely dead - ZD-915 desoldering station
                                          by armini
                                          Hi everyone!
                                          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                          Due to a lack of time, I set it aside and didn't look at it.
                                          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                          According to replies in 18VDC PSU has dropped to...
                                          04-25-2023, 07:49 AM
