Panasonic TH-42PZ70B 10 Blinks
  • 24mech
    Badcaps Baby
    • Feb 2014
    • 103
    • United Kingdom
    Hi there all, I'm hoping the fix for my 42' will be easier than the 50' is turning out to be .Turned the 42' on the other day and it started with the 10 flashes error tom66 said this was an easy fix so here's hoping, any help would be greatly appreciated thanks.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Panasonic TH-42PZ70B 10 Blinks
    if this is the same as the 42in ive recently fixed its just those two 1 uf 50 volt capacitors on those two moduels on the psu. i removed the psu then unsoldered the moduels just make a note which on went where as there different i have read.
    http://www.youtube.com/watch?v=LjpGKaBt8hg
    • tn245
      • Oct 2013
      • 530
      I've had one of these with 10 blinks. MC301/MC201 on the PSU may be the issue. Look into changing the 1uF caps and then possibly the TEA1610T ic.
      But..
      .. mine turned out to be something much simpler - a connector (DG3 I think it was) on the DG board wasn't seated properly. So check the connections first and save yourself some trouble.
      The thread about the TV I worked on:
      https://www.badcaps.net/forum/showthread.php?t=32546
        I'm getting one of these in about a week with the same issue - so hopefully another easy fix. Will document it.
        • 24mech
          Badcaps Baby
          • Feb 2014
          • 103
          • United Kingdom
          Thanks for the responses Vince, tn and tom I'll replace those 1uf 50v caps and check the connectors for position and security and report back (I look forward to toms documenting of the fix in a week or so) thanks
          • 24mech
            Badcaps Baby
            • Feb 2014
            • 103
            • United Kingdom
            can you remember the polarity for the caps? was it negative towards the IC or away from thanks
            • vinceroger69
              • Mar 2012
              • 6714
              to the top of the module shows you in the video too just make sure you change the right capacitor.
              http://www.avsforum.com/t/1001318/ma...urning-on/1350
                It is a slightly different model Vince yours was a PZ80. PSUs are different.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  does it have those two moduels? or is it completly different?
                    It has slightly different modules but they have a similar fault.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      whats the fix usually any ideas? no 15 volt issue i guess
                        Similar caps on the P board modules fail, sometimes TEA1610T fails too.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          so still usually a easy fix then i have seen the repair service offered on ebay
                          http://www.ebay.co.uk/itm/PANASONIC-...-/150736850400
                          alot of money if its one or maybe 2 parts that need replacing
                            That is a brand new module not a repair.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              sorry yes just looked put the wrong link in was looking at two haha one offers the 7 blink fix and also the 10 blink fix if you send the boards to them.
                                Yeah I've done a 7 blink repair before. Unfortunately 7 blinks can ALSO be caused by bad plasma panel. I'm not sure what the percentages are but a fair few are bad panels. If not, it's usually one or two transistors, D2PAK type. Need hot air to take off properly - can try with soldering iron, but it's difficult.
                                • 24mech
                                  Badcaps Baby
                                  • Feb 2014
                                  • 103
                                  • United Kingdom
                                  So if the modules are slightly different do I still fit 1uf caps or... and the polarity is it negative to the IC or not, also is it still the cap top left of the IC? thanks
                                    Is the chip a TEA1610T? Hard to see for sure.
                                    • tn245
                                      • Oct 2013
                                      • 530
                                      It should be a TEA1610T. See my thread - I went through the same questions about the different modules and which cap, + the value of the cap. In the end I decided it was the cap top left of the ic. I looked up pinouts of TEA1610T vs TEA1611T and compared which pins the caps were connecting to. I tried to measure the capacitance of the removed caps but they're so tiny I ended up detroying them just trying to get some leads attached to stick in my capacitance meter. So I just assumed they'd be 1uF and replaced them - I used non-polarised film caps. It worked fine and still is as far as I know.
                                      • 24mech
                                        Badcaps Baby
                                        • Feb 2014
                                        • 103
                                        • United Kingdom
                                        Yep they are TEA1610 not 11s
