viewsonic n2750w model vs10576-1m repair questions
  • Drunk Monkey
    • Jan 2014
    • 9
    • us
    ok,I am trying to fix my sisters viewsonic n2750w model vs10576-1m
    After reading a couple posts I have determined that it has the 2 sec to black problem. or more appropriately the half second to black. the tv seems to function fine, sound but I can only see a picture by shining a flashlight on it. But the tv is functioning fine otherwise. After reading https://www.badcaps.net/forum/showthread.php?t=10419 this thread I thought maybe it was a transistor because it was so quick to go to black.
    so after taking the back off I found three boards.
    Main board
    power board
    and audio board
    after visual inspection all capacitors look fine. Since the sound is fine and the main board seems overwhelming I am focusing on the power board capacitors. After taking the power board to an Electronic repair friend he said replace the 4 larger capacitors at the top of the board 2 1000uf 25v and 2 1000uf 35v. After being told panasonic makes a quality capacitor I picked some up. I installed the capacitors and plugged in the tv and it did not fix the problem. Also there has developed some sound coming from the speaker which I am told can also be caused by some of the smaller capacitors on the board being bad. Since then I have purchased the "MK - 168 TRANSISTOR TESTER"
    If anyone knows anything about this meter, it did not come with instructions but I am figuring it out. One of the pluses of this meter is that it measures ESR. I am not use to working with ESR so I am learning more about that every day.
    So here are my issues:
    I plan on removing all the capacitors and testing them off the power board this week hopefully I will find an abnormality and maybe just order a new set for the board and replace them all anyways. Is there a standard esr I should look for? If I remember correctly it should be around 18 -20? I cant help but think my thoughts of the transistor being problem. I need to figure out how to test transitors with this tool(if anyone has any ideas). Can transistors be tested in circut?
    I also wanted to get a group opinion as to if i am on the right track, any other idea might solve the problem.
    Thank in advance for all your help.
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
