Where do I get the software for Sony / Hisense tvs to install to emmc?
EMMC question and identification
Yea sorry, answered most of my questions with research.sorry man yours misunderstanding from your first post before you edit it and after edit it , eMMC / NAND to program them before install them on boards need dumps... it both blank and after installing them on boards need the SoC tool to write normal firmware to them,
Yes where are the dumps from? Is there a website or a place for these dumpsComment
Will the TV still work if the RPMB is left blank (as is the case of a freshly purchased EMMC)?
Is it known if the TV vendor uses the same contents inside the RPMB region regardless of the model number of the TV? Maybe with some compatibility luck, we can take the EMMC from other models of the TV -> reflash the EMMC to fix the target board. For example, Hisense (!!).Comment
If the EMMC is corrupted, (I assume that means the dump is corrupted?) will the dump still be usable?the dump actuality from the original parts if the programmer software can handle dump it in blocks,,, but the best way always to use SoC tools fpr blank chips
lotas could help with dumps ..... but keys need to write too in additional
When I watch the Nick's TV video on a Hisense he says he has an original software version for the EMMC, and after installed all additional updates are applied. So he would of got this from a new emmc and just copied the dump file?Comment
if the SoC in tact the Flash tools of SoC with low level adapters of the programmer can send row firmware in correct block while the TV MB under the programmer , not as TV turn on or not. this level mean MB out side the set.
the process at vendor Manufacture going too by this way, boards stensil with pasta.. raw eMMC/ NAND installed ... oven ..... cooling... then boards sitting on bed bath to program the SW with keys.
So in summary - the RPMB keys are secure and so far, cannot be extracted? Has anyone attempted to use the EMMC from say one model of Hisense -> erase the contents (not the RPMB region which is OTP) -> apply the firmware of a different Hisense model -> does this fix the dead board?
About to invest into some tools for the same R&D so your valuable feedback will save some time. Which is the best and affordable EMMC toolkit? UFI box? The Z3X Easy-Jtag Plus is the latest but $$$ ?
From a quick review, the lower cost tools are using 1 bit mode to access the EMMC so takes hours to R/W the contents. Is this correct? The faster units like Z3X Easy-Jtag Plus are operating in 4-bit mode? There is ~$100 USD in the hardware to R/W to the EMMC using a zero force socket but the real work is in the s/w to control this hardware. There are FPGA IPs to operate with EMMC and also STM32 code.Comment
If appreciate it if you started your own thread. This has nothing to do with my questionsSo in summary - the RPMB keys are secure and so far, cannot be extracted? Has anyone attempted to use the EMMC from say one model of Hisense -> erase the contents (not the RPMB region which is OTP) -> apply the firmware of a different Hisense model -> does this fix the dead board?
by EazyBoneI am extremely new to programming and dipping into this. I picked up a XGECU T48 Programmer and have the correct socket for EMMC.
I took the EMMC off a working main board with no problems and threw it into the programmer. I click analysis IC and it gives me a report (attached) of the current EMMC. Model H26M41204HPR
1) I manually found this chip(above model number) in the select IC section of the XGPRO 12.xx programmer software and it had a option for 4 bit and 1 bit. I chose 4... is this correct?
2) In the options section point number 2 operation says "30...5 Photos -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
Replaced emmc.
Terminal log
UART
AC_ON
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
This specification for the Acer Chromebook Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Silver) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen Display, Google Chrome OS, Silver) boardview and Acer Chromebook Spin 513 CP513-1H - (Qualcomm SC7180, 4GB, 64GB eMMC, 13.3 inch Full HD Touchscreen...09-07-2024, 01:00 AM
This specification for the Acer Aspire Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows 10 in S Mode, Office 365 Personal, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows 10 in S Mode, Office 365 Personal, Black) boardview and Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows...09-06-2024, 10:00 PM
- Loading...
