Toshiba 55TL515U vertical smudge bars (sometimes) pics included
  • takeitapart
    • Feb 2014
    • 10
    • US
    When the screen has darker video playing or even a darker menu screen up, there are no vertical bars. When there is bright white (text for example) in the area of the two bars, the bars show up.
    I've had the back off and the T-con ribbons are on the bottom, so liquid damage possible. It's going to be a PITA to get a close look at the ribbons but am preparing to go there.
    Any opinions before I get in that deep on bad-T-con or bad-panel?
  • takeitapart
    • Feb 2014
    • 10
    • US
    Re: Toshiba 55TL515U vertical smudge bars (sometimes) pics included
    Follow-up
    I took the front off and got to the panel ribbons. They look good. I stood it on its side, powered up, brought up the network page in the first image, tapped on the ribbons to see if any change, and no change. I removed, cleaned both ends of the T-con ribbon for that half of the screen, and reinstalled, no change.
    Any opinions?
      If you flip around the ribbons for the t-con, does the symptom change?
      note: do NOT attempt to connect left t-con out to right side of panel. High chance you could fry panel instantly. Pin out is mirrored between the sides in most cases.
      • takeitapart
        • Feb 2014
        • 10
        • US
        Follow-up 2
        I swapped the cables and no picture at all???
        Put them back and same issue.
        I got out the contact cleaner and a jeweler's loop and sure enough there was corrosion inside the PCB under the ribbon that fed those two sections.
        Enough to make a grown man cry!
        Beautiful set with so many great features destroyed by really poor engineering and a dumbass with a spray bottle. (Good engineering factors in dumbasses.)
        Scratch Toshiba from my future purchases list.
        Thanks for the reply/assist Tom.
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • ninja_zx11
          Sharp LC-70LE650U vertical black and red bars
          by ninja_zx11
          70" LED TV is Sharp LC-70LE650U.
          Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
          07-07-2023, 11:27 PM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • JesusJones
          Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
          by JesusJones
          Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
          The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
          04-13-2021, 01:45 PM
        • mopenstein
          Looking for Vertical IC for RCA Chassis CTC159L CRT
          by mopenstein
          I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
          Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
          I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
          09-24-2023, 10:41 AM
