sony kdl-55ex720 i have backlight and a blank stare on my face
  • smai
    • Dec 2013
    • 69
    when the unit is powered on i will get the sound of static (see video) OR the sound of analog tv with bad reception kind of static for about 5 seconds then blank screen, some buttons make noises some dont, cant change inputs, cant bring up any menus, its just a black lit screen.. (actually now that i think of it, when i 1st plugged it in it showed static like channel 3 on analog but it faded to black and now is only)
    the video attached however is me "resetting" the tv by holding the up arrow on the remote and pressing the power button strange result
    i just inherited the TV so im not sure what led up to this, i found the service manual which ill upload here for future searchers
    my gut is telling me the main board is toast maybe a corrupt firmware or bad flash or something on the main board failed, but my brain is saying that would cause a blinking light so i dont know
    thoughts anyone ?
    http://s59.photobucket.com/user/joeb...baf71.mp4.html
  • freakaftr8
    • Oct 2012
    • 3743
    Re: sony kdl-55ex720 i have backlight and a blank stare on my face
    I would start by pulling one ribbon cable from t-con board to panel and try powering it up see if half the screen comes on then if that side doesn't replace that cable and pull cable on opposite side and see a screen comes on That side. what we're looking for is a possible short in the main panel itself but this could also be a tcon for issue
    • smai
      • Dec 2013
      • 69
      i just briefly talked to the previous owner they said they cleaned it with windex and it happend.... i dont think that would do anything unless you doused it in windex
      thanks ill try that
      • R_J
        • Jun 2012
        • 9535
        I see that the T-con is located at the bottom of the panel,, I will guess that the windex ran down the screen and onto the lcd display circuits where they connect to the actual panel.
        • freakaftr8
          • Oct 2012
          • 3743
          if you're lucky it might have just shorted out the Tcon Board and the panel still is still okay
          • smai
            • Dec 2013
            • 69
            i did this no change
            YES this is the case i found blue residue on the board that is hard connected to the actual display, it was on one a small area and some of the connector
            So i pretty much took the whole TV apart and cleaned up all the residue and the connector still same result and again its the whole screen not just one side, i have inspected the t-con nothing looks obviously bad and the 2 fuses are continuous
            Any thoughts on more diagnosing/testing or which board to replace?
            • smai
              • Dec 2013
              • 69
              if the t-con didnt get wet could it still have shorted out from the other board getting wet?
              do you guys think im fighting a losing battle here with a "windex wetted" panel ?
              • smai
                • Dec 2013
                • 69
                just an update i was able to update the firmware (blind) and now i can get the audio to play (only HDMI tested) but still no video it seems like the TV is working as normal besides displaying the video, the chip on the t-con board get pretty warm
                i also attached the service manual, for future reference for anyone searching, and it seems like theres no real way of testing, just replace and if it doesnt work replace the next board and so on
                what do you think shot display ? t-con? BATV? LD?
                • truep
                  • Aug 2010
                  • 373
                  I have several sets with corrosion on that board. None were repairable.
                  • smai
                    • Dec 2013
                    • 69
                    so i got the TV to display random moving lines with some color only on one side of the screen by disconnecting the other side, the side that displayed something was the windex effected side
                    does this give any clue on the part that is at fault? would i be wasting $60 on a t-con board by giving it a shot?
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                    • hasel17
                      CH341a can erase and read but can't write and blank check
                      by hasel17
                      So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                      Code:
                      Checking for blank...
                      (Press
                      10-26-2023, 06:20 AM
                      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                      09-06-2024, 05:30 AM
