Panasonic plasma TH-46PZ80U 7 red lights--fixed it--but now it's back
  • Zelek11
    • Feb 2014
    • 5
    A little over a week ago my Panasonic plasma, model TH-46PZ80U, gave me the 7 red blinking lights of death. I started troubleshooting, trying to figure out which board(s) had gone bad. When I tried just disconnecting the ribbon cable from the SC board and powering on the TV, the blinking lights disappeared. So, I plugged the ribbon cable back into the SC board and for a week now have been watching the TV with no problems.
    Until today. Now the 7 lights are back. So I once again disconnected the ribbon cable from the SC, powered on the TV, red lights are gone, reconnect the cable, and TV is now working again. So I'm a little confused as to what is going on.
    My questions are:
    1. Why did removing the ribbon cable "fix" it for a week?
    2. Why have the 7 blinks come back?
    I have read that after fixing the SC board you should (re)install new firmware otherwise the TV will remember that it has a bad board. I have searched all over the web for new firmware for this model and can not find any. Is a factory reset in the on-screen menu the equivalent of resetting the firmware?
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • stecos
    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
    by stecos
    Hi everyone!
    I happened several times, in the search for help from the web, to consult this very interesting forum.
    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
    Having said that I come to the gist of my post on the forum as the title suggests.
    For my passion for technology I'm now collecting several...
    11-28-2022, 11:39 AM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
  • Lintesir
    Panasonic P42S30 Plasma - Pink sparkles
    by Lintesir
    My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
    There is about a 5cm high region at the top without any sparkles,...
    07-26-2024, 03:16 AM
  • badcappo
    Dead Panasonic Viera TX-P65STW50 Plasma TV
    by badcappo
    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
    Diode type G972s6 - D101 with a short
    Mosfet 06N90E - Q301 shorted
    Fuse T5AH 250V - F103 blown
    Diode D301 shorted
    Relay DG1U-17VDC II - RL001 blown
    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
    11-24-2024, 11:27 AM
