Proscan PLDED3996A led backlight help
    Re: Proscan PLDED3996A led backlight help
    What does pin ON/OFF read with multimeter black on chassis, red on that pin?
    • boxingfan
      dumb
      • Jan 2014
      • 35
      • usa
      3.5v with tv on, thanks
      • boxingfan
        dumb
        • Jan 2014
        • 35
        • usa
        Is that reading ok?
          That reading indicates main board is switching on LED backlight. So fault is with PSU or backlighting.
          Can you remove the power board carefully (turn TV off for 30 minutes - unplug at wall - before doing this) and take pictures of the bottom of the board?
          • boxingfan
            dumb
            • Jan 2014
            • 35
            • usa
            this is the back of the psu, is this what you want? thanks you i know is not fun to help a dumb guy like me
              Need a clearer photo of top left of this board - ideally with consistent lighting and sharper focus.
              https://www.badcaps.net/forum/attach...5&d=1391989814
              One tip with board photos: taking a board out into pure sunlight can help. Try using macro photos. If you have a smartphone or camera with tap to focus, tap on a large dark object with contrasted edges, like the device in the top left, to help improve photos. I am able to get super-sharp photos with a Galaxy S2... which is nearly 4 years old and only 8 MP sensor.
              • boxingfan
                dumb
                • Jan 2014
                • 35
                • usa
                #27
                any better? im using an iphone 4 that i know doesnt have the best camera, if not ill get a better camera and sunlight tomorrow, thanks
                  I will try and come up with a response tomorrow (too late right now), but if I happen to forget, please reply again. Photos look usable enough to understand circuit, but I will ask for part #s in trying to decode it.
                  • boxingfan
                    dumb
                    • Jan 2014
                    • 35
                    • usa
                    #29
                    thank i just noticed that i took pics of the top right, here is what you ask me, thank you, yea it is late for you (uk) i,m at -5 GMT, so see you tomorrow ill bump this thread
                    • boxingfan
                      dumb
                      • Jan 2014
                      • 35
                      • usa
                      #30
                      Bump
                      • boxingfan
                        dumb
                        • Jan 2014
                        • 35
                        • usa
                        #31
                        TV is alive!!!!!!!!!! Thanks everyone especially to tom66 for point me to the right direction
                        It was a bad transistor(QS12)
                          Nice one, sorry I did not have time to get back to you, how did you determine that to be at fault?
                          • boxingfan
                            dumb
                            • Jan 2014
                            • 35
                            • usa
                            #33
                            i was going from the on/off pin to the other end testing all components and following the beep, and when i checked the QS12 i got O.L where ever i put the proves so i decided to pull it off and replace with one i took from one of the many boards i have, and i got lucky,i paid $30 for it
                              I'm very surprised that any random transistor would work but nice fix!
                              Do verify that backlight turns on/off OK - for example when switching sources, you do not see noise or errors on the screen which clear shortly after.
                              • boxingfan
                                dumb
                                • Jan 2014
                                • 35
                                • usa
                                #35
                                it has been on for about 1 1/2 h, i did an ota scan, tested all hdmi outputs. lights comes on and off normally, i dont see anything wrong(yet) lol, i'm gonna keep the tv on and going through all the menu
                                • boxingfan
                                  dumb
                                  • Jan 2014
                                  • 35
                                  • usa
                                  #36
                                  The transistor I got is very similar to the QS11 that is next to the QS12. Do you think the QS12 and the QS11 are different ?
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                    MSI Trident 3 White 8RD-048 Trident i7-8700 Specification for Upgrade or Repair
                                    This specification for the MSI Trident 3 White 8RD-048 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 White 8RD-048 boardview and Trident 3 White 8RD-048 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-12-2024, 03:28 PM
                                    BLUECHIP BUSINESSline N11030 white i3-10110U Specification for Upgrade or Repair
                                    This specification for the BLUECHIP BUSINESSline N11030 white can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline N11030 white boardview and BUSINESSline N11030 white schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-12-2024, 02:20 PM
