Sony XBR-55X930D Magically turns itself on
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I got paid to take this. It had the typical bad STBY IC on the DPS board. Replace it and life was grand....or so I thought. I've never seen this one before; this TV will just magically turns itself on for no particular reason on earth. I did a hard reset on it (twice) clearing all data & settings out.....will still do this. Even removed the batteries from the remote....in the unlikely even there was a stuck key... Still doing it. I did not set up any of the 'smart' functions, I just fed it a source from a HTPC. It doesn't matter what input is selected.....still does it. No rhyme or reason as to frequency. Stayed off all weekend (thought I had it beat)....then all of a sudden today I was in the workroom working on something else and it came on.... Turned it off....a few minutes later, back on....rinse repeat. Time increments between powering itself up are not the same (I did time it out of curiosity). Sometimes it'll stay off for 2 minutes, the next time it might take 20 minutes.... All timers are off. Bravia 'sync' is off. I'm out of answers.
    It otherwise works fine. Gorgeous picture on it....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Try disconnecting the control buttons (joystick) from the motherboard and test without them (the power button may leak and create a false switch).
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      ...but wouldn't this cause it to turn off or if stuck long enough cause a reboot? It doesn't do either of those. It'll stay on until turned off again.... I will try it though....but I don't think that's it. Spooky.
      Team : 49813
      Join in!!
      Team Stats
      • EazyBone
        • Jun 2023
        • 1353
        • United states
        That was my thought also. Disc the buttons. Maybe someone has a remote through wall if your at apartment.
        • ivtec
          sony kdl 32 bx 300 turns off and back on help
          by ivtec
          Hi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv...
          07-03-2024, 10:52 AM
        • Yosua
          sony vaio MBX-237 every 35 seconds it turns off again
          by Yosua
          hi friends, I want to share about my problem with the mobo SONY VAIO MBX-237, the case is when pressing the power button it turns on (without display) but in 35 seconds it turns off again, I have measured the resistance on all coils, and the result is 1 coil near the vga chip there is no voltage when the mobo is on, and my problem is because on this mobo there is no code for each component, I hope someone can help me here, thank you....
          03-27-2022, 08:14 PM
        • Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
          by Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
          03-15-2024, 09:37 AM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
