Panasonic Plasma TX-P42G20B vertical bar
  • ezquerro
    • Feb 2014
    • 15
    • england
    I have a Panasonic TX-P42G20B 3 yers old with a vertical line, appears in the center of the display:
    http://www.1x2.talktalk.net/l3.jpg
    anybody know how to fix it?
    what part is faulty ? how much cost? and where I can buy it?
    Re: Panasonic Plasma TX-P42G20B vertical bar
    Take the back cover off the TV and post a clear photo. Likely just a loose cable. If not, could be a bad C board. Should be fixable. I've heard this is a fairly common issue with these panels.
    • ezquerro
      • Feb 2014
      • 15
      • england
      I think the flex is not loose because is fited by 2 screws, I will open back cover again on saturday and make a clear photo.
      @tom66 where I can buy a C-board for my tv ?
      the vertical bar is fluctuating, more photos:
      http://www.1x2.talktalk.net/l1.jpg
      http://www.1x2.talktalk.net/l2.jpg
      http://www.1x2.talktalk.net/l4.jpg
      http://www.1x2.talktalk.net/l5.jpg
      http://www.1x2.talktalk.net/l6.jpg
      http://www.1x2.talktalk.net/l7.jpg
        C board can be found on eBay, FlatTVParts, parts4u.me.uk, Emos' used TV spares, etc. Just match up TNPA or TNPH number including suffix code, e.g. "AG", "AH", if one is present.
        • ezquerro
          • Feb 2014
          • 15
          • england
          thanks tom66
          I have checked on ebay but can't find a new one , all used
          it's correct part numer for my faulty c-board? TNPA5094
          I would like check my c-board for shorting but i don't know how do it, do You have any troubleshooting ?
            You won't find a new one. They are all used from scrapped TVs. Panasonic new one would be 3 digits+, if they even sell it any more.
            • ezquerro
              • Feb 2014
              • 15
              • england
              I noticed something, when disconnecting flex and connecting again there is no line on tv
              but appear again after 30 minuts. The metal frame on flex starts heats up, I'v checked others one and is no heating like that.
              Tom66 are you sure that c-board is a defective ? not flex ?
              http://www.1x2.talktalk.net/heats.jpg
                It can possibly be that ribbon. There is unfortunately no way of replacing it.
                NOTE: You MUST have the screws in place when powering it up or further damage could occur.
                C board looks cheap, I'd take a chance on that. If not, it is the panel, sadly...
                • ezquerro
                  • Feb 2014
                  • 15
                  • england
                  thanks Tom66 , I just ordered c-board
                  • ezquerro
                    • Feb 2014
                    • 15
                    • england
                    I just replaced c-board, works fine only for 10 minutes and line appeared again
                    after one hour line disappeared and appeared again after 20 minutes
                    any ideas ??
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Prob the COF chip on that flex connector. Part of panel, sadly unreplaceable as its part of the panel assay.
                      TELEFIX
                      • ezquerro
                        • Feb 2014
                        • 15
                        • england
                        it is possible to check that chip is faulty?
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Apart from what you have already done--ie, replace everything else, no--I don't think so....
                          I scrapped a Pan a few weeks ago with the same fault, although with mine--it was permanent.
                          TELEFIX
                          • ezquerro
                            • Feb 2014
                            • 15
                            • england
                            now my tv back to normal but I dkon't know for how long...
                            made a video:
                            https://www.youtube.com/watch?v=Zzfe...ature=youtu.be
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • stecos
                              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                              by stecos
                              Hi everyone!
                              I happened several times, in the search for help from the web, to consult this very interesting forum.
                              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                              Having said that I come to the gist of my post on the forum as the title suggests.
                              For my passion for technology I'm now collecting several...
                              11-28-2022, 11:39 AM
                            • cloo
                              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                              by cloo
                              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                              After doing a factory reset this problem was gone and the picture was back to...
                              01-06-2025, 06:02 AM
                            • Alicat
                              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                              by Alicat
                              Stopped by this site trying to fix my parents Panasonic Plasma TV.
                              Model number is TH-50PZ85U
                              Power comes on and the red power light stays on solid.
                              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                              I also hear a few clicks.
                              I also think my parents said there was a thunderstorm and the TV failed after that.
                              Section 6 in the service manual talks about power and no screen,...
                              10-30-2024, 10:09 AM
                            • Lintesir
                              Panasonic P42S30 Plasma - Pink sparkles
                              by Lintesir
                              My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                              There is about a 5cm high region at the top without any sparkles,...
                              07-26-2024, 03:16 AM
