Lg47le5300
  • sordids999
    • May 2013
    • 2161
    • uk
    Lg47le5300
    hi guys
    would anyone know the EBT or EBU number from this main board i have looked everywhere ?
    my board number is LD01D EAX61766102(0) 2009.12.23 H.Y.D
    there are a few on ebay but with different EBT/EBU numbers so dont want to get the wrong one
    thanks
    Re: Lg47le5300
    EAX = assembly number, try ordering by that, rather than EBU/EBT which is for bare PCB IIRC... If LVDS connector, inputs and other connectors are the same, it should be OK.
    • sordids999
      • May 2013
      • 2161
      • uk
      Re: Lg47le5300
      ah ok m8 just noticed there is a 32 inch board LG32LE5300 for sale was not sure if it would work in a 47 inch
      thanks tom
        Re: Lg47le5300
        Yes trying that might not work. You should try using 47 inch board because the panels are more likely to be compatible.
        • sordids999
          • May 2013
          • 2161
          • uk
          Re: Lg47le5300
          Ok so I've got this TV back out before I order a main board anyone got any ideas to check if its the main board that's gone ?
            Re: Lg47le5300
            Could you tell us the fault? For those of us who do not have psychic abilities :P.
            • sordids999
              • May 2013
              • 2161
              • uk
              Re: Lg47le5300
              Opps stupid me right all I can do is basically turn on the TV via the remote and I get a long beeping sound and that's it
              • sordids999
                • May 2013
                • 2161
                • uk
                Re: Lg47le5300
                Meant to say I ordered a PSU replacement ages ago but still the same problem
                  Re: Lg47le5300
                  Where's the beeping coming from? Speakers, main board, other?
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    Re: Lg47le5300
                    Remote sensor power on lights up with long beep but goes off after 5 secs plus the power light if that makes sense
                      Re: Lg47le5300
                      So, during this time, check PSU voltages. See if they're good.
                      • sordids999
                        • May 2013
                        • 2161
                        • uk
                        Re: Lg47le5300
                        Right on the PSU is
                        Not sure if this is pin one but ....
                        Pin 1 20v (0.0) pin 2 Power on (0.0)
                        Pin 3 20v (0.0) pin 4 20v (0.0)
                        Pin 5 gnd. Pin 6 gnd
                        Pin 7 gnd. Pin 8 gnd
                        Pin 9 3.5v (3.2). Pin 10 3.5v (3.2)
                        Pin 11 3.5v (3.2). Pin12 3.5v (3.2)
                        Pin 13 gnd. Pin 14 gnd
                        Pin 15 vsync. Pin 16 gnd
                        Pin 17 DRV on pin 18 12v (0.0)
                        Pin 19 sclk. Pin 20 12v(0.0)
                        Pin 21 Pwm dim. Pin 22 12v (0.0)
                        Pin 23 err out. Pin 24 sin
