Wondering if any knows where I can find a Thermistor. 20ohm 6amp have looked on Digi-Ki and a few others the number on it is SCK 206. any help is much appreciated.
Part Search?
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Part Search?
Might help if we knew where you lived? please update profile with country and mains voltagePlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
by edugimenoHi There!
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by YanlebIn the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
For an example, look at the attached PDF.
Do you have a way to cross reference the Panasonic part number with the actual part number?
Thanks....07-03-2023, 08:16 PM -
by FreakyMexHello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...02-17-2025, 01:16 AM -
by esiniorHi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
I've attached pics of this part
Thanks...4 Photos -
by ty34Hi,
I have a broken Latitude 5530 with a damaged part which is marked PU4501.
The laptop wont turn on and i can only assume this part is the reason!
Can anybody supply a manufacturers name and part number so i can swap it out, and hopefully get a working laptop?
Thanks1 Photo - Loading...
