LG 50PC3D-UD Power Supply Repair
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PC3D-UD Power Supply Repair
    Hmm you will need to find a schematic or capacitor repair kit that has the cap positions listed.
    • hisalive
      • Aug 2015
      • canada
      thx for responses after an exhaustive search I found a schematic to a similar board and found that c261 is the 680uf cap! Now lets hope my recap works, though doubtful.
      • FLLARRY
        • Mar 2016
        • US
        Originally posted by hisalive
        Good Day, have a similar issue, I've started by pulling and replacing the 10 3300uf caps on the secondary side of the supply, unfortunately I noticed I pulled a 680uf cap that was amongst the 3300's, now I have no idea what spot it goes back into, anyone have a board to check and let me know? Much appreciated.
        If you still need the location info, please let me know. I'm working on the same problem ! Samwha caps are used throughout the set (It has worked for 10 years with no problems !)
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
